Question about Samsung HL61A650 TV
Hl61a650 replaced bulb three times in last two mo. also replaced the ballast went to turn tv on and back to three blinking lights
3 Suggested Answers
SOURCE: Sony Grand vega 55" will blink green for three times than red
Your problem is your thermal fuse.It is located around the bottom of the compartment that houses the lamp. You will have to remove the lamp and take the bottom back panel off. Then you will have to remove the fan. I ordered the thermal fuse so I would know what I was looking for when I started to replace it. If you take your time and are patient enough you can fix it yourself. I fixed mine and it's working great.GOOD LUCK!!!
Posted on Jun 23, 2009
milkburp
  • 416 Answers
SOURCE: I have a Samsung HLT5075s. Last Sunday the Tv
Not the light engine. But it could be the power supply. I've seen a few than pass "dirt" power to the ballast and damage it. Have a peek at the ballast, there's a big 47uf, 450v capacitor on it. If it is swollen, it's a dead give away. You need both. I hope this was helpful.
Posted on Mar 30, 2010
I just replaced the bulb last week, yet this time the TV will still not turn on and all three lights are still blinking.
It is possible that the replacement lamp is bad but more likely the TV has a protection mode that triggers wen the lamp goes out. Check the manual for ways to reset the lamp usage back to zero or a function that needs to be manually reset when the lamp is changed.
May 02, 2015 | Televison & Video
DLP won't fire up...
Try first unplugging power cord, see if it reset.
Jul 26, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Hl61a650 dlp bulb wont fire up color wheel may need replaced?
True or it could be a bad bulb or ballast or door switch, it can be many things, first make sure bulb is good. and that ballast is striking.
Mar 07, 2011 | Samsung HL61A650 TV
Samsung dlp hl61a650c1fxza turned off in the middle of the nfl playoff game. Turned it back on and the blue on/off button stays lit but the three lights (red, green, green) blinks constantly with no...
Hey dsfrank6088, i have the same issue right now. I called tech support and they are telling me that i need to change the light bulb which i did less than 3 months ago. Please let me know if you did find a solution!!
Jan 19, 2011 | Samsung HL61A650 TV
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
Feb 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Samsung HL61A650 TV Logo
108 people viewed this question
Henry  Thomas
Henry Thomas
