Question about Nilfisk 350-01 Wet Washer
Hi my nilfisk alto e140.1 has just cut out i have changed the fuse its not that could someone please help because i have borrowed it off a friend :( helen....
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I had the same problem, turn on nothing happened and then the fuse popped. Once I had opened the unit up it was obvious the Capacitor had failed. New part sourced from that auction site from a company called 'reliant-cleaning-services' the replacement part sourced was '25uf 450v Capacitor Universal to Fit Washing Machine / Tumble Dryers' Cost £2.75 delivered and it's been fine ever since!
Hope this helps and good luck. :-)
Posted on Jan 13, 2015
  • 710 Answers
Hi Helen,
I checked the owners manual. Here are some things you can check:
The thermal sensor has shut it down. The manual says to let it cool down for 5 plus minutes, then try it again. I imagine you've tried that already, so ....
The nozzle could be partially blocked. The nozzle MUST be detached in order to clean it. Use something as long as the nozzle, like a stiff wire or needle like object, to clear it. Then flush it backwards with water.
Since the fuse blew, try the machine without the extensions hose or use a little higher rated fuse or both.
The pump/spray gun is leaking.
If none of these works, please reply back.
I hope this does work. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 06, 2011
Hi I have a nilfisk alto that has not been working properly. It has not been spraying the water
Alto nilfisk vaccuum is not spraying water , a highpressure washer do you mean not a vaccuum .
But If it's an alto nilfisk blue pressure washer on the vaccuums topic it must be the bypass / autostop on the pumphouse its internally a point where a microswitch is placed and depends on the type of washer by a problem with the parbak ( a parbak is a oring/ with auxiliary kevlar ring(s)) that can hang on lime, but on an other model there are 2 springs on the bypass and one of them the great spring is broken or only hanging on lime but thats rare if it is.
I don't know if there are vaccuums with water spraying only for remove dust.
Feb 15, 2017 | Nilfisk Vacuums
I need instructions on how to dismantle my nilfisk multi 20
Hi There,
If you need parts diagrams for any Nilfisk machines just use the contact us form on our website and we will be happy to get one for you.
Sep 30, 2012 | Nilfisk VT60 Wet/Dry Vacuum
Fault Nilfisk Alto pressure washer
see the diagram and repair swtich:
May 14, 2012 | Vacuums
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
Do alto clarke have a supplier in Australia for vacuum cleaner parts? D T V 7 Thankyou
HI there Vacuum Guru here from VacuumSpot.com.au. Most alto clarke share the same parts as a Nilfisk Alto. We are an agent for these machines. If you use the email link on our site and let us know which model you have we should be able to get you any parts you need.
Oct 14, 2010 | Alto 302000405 Attix 8 Canister Wet/Dry...
Vacuum emitting strong odors when it's on.
Hi there SmartAlec from NelsonVacuums.com.au here. I am a nilfisk vacuum agent and although i havent actually worked on one exactly the same as yours there are no Nilfisk with any kind of washable filters at all. I think you will have to replace it. If you are in Australia i can check out the cost of replacement filters for you just drop me an email with the exact model number.
Hope this helps.
Happy Vacuuming :)
Aug 31, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Not working,need assistance from anybody or cheap parts.thanks
sounds like the trigger switch is stuck.try to spray a little wd40 up into the switch and work it ,maybe it will free up.if not the switch is probably bad
Apr 29, 2009 | Vacuums
Nilfisk c120 vacuum - no power
The fuse is part of the motor so is not something that can be changed. Make sure that there isn't a break in your power lead at the plug.
Mar 15, 2009 | Vacuums
Need filter
Check with www.ultimategarage.com or www.industrialvacs.com. They are both stocking dealers for Wap/Alto/Attix vacuums, now a part of Nilfisk of Denmark. Good luck
Mar 03, 2009 | Wap 28538 Wet/Dry Vacuum
Nilfisk 350-01 Wet Washer Logo
731 people viewed this question
Top Nilfisk Vacuums Experts
Jim Parker
Jim Parker
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
