Question about Saitek Pro Flight Yoke System Flight Simulator
My Saltek flight yoke is not functioning anymore. Depending on the mode it is switched to, either the roll axis or the pitch axis is always on one extreme end, for example on mode 1 the ailerons are on a left turn configuration without me touching the yoke. After centering, they drift again by themselves towards the endstop. On mode 2 or 3, it's the same with the elevators but then the ailerons are OK. Also, the throttle module seems to ignore a reverse thrust command. I am using an Imac 24 about 11/2 years old with a MAC OS 10.6 Snow leopard software. The CD that came with it is only for windows. Thank you
  • jandebaumann Apr 06, 2011
    Hi Aplug
    Thank you for your reply but pretty well all you wrote was already known to me. The yoke was functioning fine with all buttons and levers working well for about 8 months up to about 2 weeks ago when it started acting up, so I do not understand some of your explanations. Unless there is some way to re-program the yoke, it seems there is an electronic problem somewhere in there. But please remember that I have an Apple computer.
    H.B.
  • jandebaumann Apr 07, 2011
    Hi Again
    Yes, I agree with your last assessment, because that is exactly what makes the most sense. However, what I was looking for is a place or person to contact who is able to do this, because I am not into electronics at all. I know it is not rocket science, but I am afraid this needs more knowledge about the subject than I possess. Thanks for the advice.
    H.B.
  • 11,800 Answers
This is a hardware defect , nothing to do with the drivers, software or the OS you are using in .
The position and movement of the control elements is recorded by a simple rotating potentiometer. The analogue signal from the potentiometer is converted to digital by a simple AD converter circuit inside it. If one of the control elements no longer reacts properly the first thing you must check is the corresponding potentiometer - open the unit, access the potentiometer and see if you can repair or replace it. Then check the status of the components on the control board and finally the wire connections between all of them - a wire might have been broken.
Posted on Apr 07, 2011
  • Azrael SRL Apr 07, 2011
    This is a relatively simple job, your local electronics repair person/shop will be able to do it without a problem. But, because the labor costs are so high these days, you should try to take a look yourself, maybe all it needs is a cleaning of the potentiometer. Just dismantle the unit gently, as to not brake the plastic parts, they are fragile.
    President:
  • 1,961 Answers
The Yoke is supplied with all the clamps and screws that are required to fix your controller to your desk unit. The installation manual will help you with this.
The throttle quadrant that is supplied with the Yoke has a round PS/2 connector. This plugs into the PS/2 port on the side of your Yoke (not the PC). Your PC and FSX will not recognize the Yoke and the Quadrant as separate controllers. They are seen by your system as one device, hence the quadrant will not work on its own with a PS/2 to USB adapter.
Check the PS/2 pins are OK and then connect the quadrant to the yoke and connect the USB to the PC to power both units. You can then run the driver and software installation,
Before you even start up your flight simulator, you should acquaint yourself with some of the controls and features of the Yoke. Go to Control Panel > Game Controllers and select the Properties for your Saitek Yoke (I'm sorry, but cd installer is designed for windows). Here, you can test your buttons and axes to check that they are working correctly.
The Yoke has 5 axes, 2 on the control yoke itself and 3 lever axes. The Yoke has a POV switch and 8 programmable buttons. There is also a Mode Wheel on the back of the right handle that enables you to change the mode of your pre-programmed button profile. To the uninitiated, the modes apply to the Programming Software (SST) that comes with the controller. The software allows you to assign the keyboard commands from your simulator to the buttons on the Yoke. You can save these assignments as a profile, which can be tweaked as your flight experience increases. One Mode equals one configured set of buttons. So, with the SST, you can have a minimum of 3 different button configurations set to your controller at one time. You can even set more modes in the programming software itself. Instructions on this, and how to use the other features of the programming software, can be found here. The FSX profile for the Yoke can be downloaded from here.
With the drivers installed, the LCD screen will also display your PC time and a timer function. The throttle quadrant has 6 T buttons and 3 reverser buttons. They enable you to set functions such as reverse thrust (discussed below) to your quadrant. If you move your levers into the red detent section you will feel a click. These are the reverser buttons and these can be assigned like normal buttons to your Flight Sim, or programmed in our SST Profile Editor.
There are additional USB ports on your Yoke. Currently, we provide additional Throttle Quadrants, Rudder Pedals and the Switch Panel as additional add-on to the system. All these can be powered using the USB ports on the side of the Yoke. Future additions may require a bit more juice, which is why the Yoke has a port for a power adapter, so that it can be uses as a powered USB hub
Posted on Apr 06, 2011
I have a simple problem with the SAITEK pro flight yoke. The LCD display is backlit, but BLANK. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LCD DISPL
If the LCD is not working then it is likely that required drivers are either not working or missing. Try downloading updated drivers from the Saitek website.
Nov 08, 2012 | Saitek Pro Flight Yoke System Flight...
All views move to different positions when connecting the yoke, cannot pan up or down only left or right when the FSX Options-Settings-Controls-Enable contollers is not ticked. When I "enable" Contollers I...
Hello
In the control options of fsx you need to delete the default keybind for the view you want assigend to your joystick.Then replace it with your controler axis.Or you can use the software and do your own program for fsx.The views in fsx have always been an issue or a problem with the game.
Also panning down in fsx and reverting back up has always been an issue or a clitch in the simulator.it does however work in fs version 9.
Using Fsuipc with a weather program or a virtual airline should not make a difference in control settings.
Jun 06, 2011 | Saitek Pro Flight Yoke System Flight...
In FSX (Win7 64bit) couldn't get enough speed to take off! Found that when Saitek proflight quadrant set at max only around 85% power delivered. Had to use mouse pointer in virtual cockpit to advance...
Hi Alf,
This sounds like a deadzone setting not allowing the throttle axis to go full.
There are 2 places in which the deadzones can be set:
In FSX: Settings> Controls> Calibration, there select your Yoke and then set the NULL to the left, which is 0.
Or in windows in Input Devices (Win Xp - is in Control Panel, Vista or Win7 go to Games Explorer>Tools>Input Devices).
In Input Devices->Select the Yoke and click Properties, then go to the Deadzones Tab and set the deadzones for the Throttle. Mixture and Prop to 0.
Hope it helps...
Apr 29, 2011 | Saitek Pro Flight Yoke System Flight...
I have a simple problem with the SAITEK pro flight yoke. The LED display does not turn on. The usb is plugged correctly and the yoke functions correctly. All is working properly but the LED DISPLAY. ...
For how low have you had the Yoke?
This a known fault with the front display on the Yoke failing, it's caused by the LED's being faulty or a inperfect contact there.
If the Yoke functions correctly then it might be one of the above.
If you still have warranty, meaning if you purchased the Yoke less then 2 years ago, try to ask for a replacement for it either from the retailer of from Saitek.
hope it helps...
Apr 03, 2011 | Saitek Pro Flight Yoke System Flight...
On take off all aircraft veer to the left and stall in flight
if you use mouse yoke, get a joystick if you have a joystick it may be broken.
Sep 29, 2009 | Microsoft Flight Simulator X for Windows
When the yoke is pushed/pulled (the y axis of the yoke affecting the elevators of the plane) it also affects the x axis of the yoke or the ailerons of the airplane. In my case I want to gain height (pull...
although this did not solve my problem, it is worth a try to reset the calibration settings stored in the windows registry.
These are the steps for it:
To recalibrate, first unplug the controller.
Go to start/run and type 'regedit'
The registry editor will have a list of folders on the left hand side. Go
down into the following folders in order.
HKEY_LOCAL_MACHINE (HKEY_CURRENT_USER if on VISTA)
System
CurrentControlSet
Control
Media Properties
Private Properties
Direct Input
Inside the Direct Input folder, delete any folder that begins VID_06A3.
Once done, close the editor.
Plug the controller back in and move all the
axes (including throttle) through their full range of movement 4 times.
Now go to control panel/game controllers/properties to see if there are any changes to the test screen?
If it helps you, it didn't do it for me ;) but I reckon it's worth a try
Jun 11, 2009 | Saitek Pro Flight Yoke System Flight...
SPOT VIEW FIXED
You need to assign what view you want to the cooley hat on your controller in FSX\Settings. Rethe Zoom, press the backspace key to reset it, then use the + and - keys to zoom in and out.
Apr 22, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek Pro Flight Yoke System Flight Simulator Logo
410 people viewed this question
Top Saitek Video Game Consoles & Games Experts
 TE5LA
TE5LA
Rob Emerson
Rob Emerson
juanmireles1
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
