Question about LG LDF9810ST Built-in Dishwasher
Hello I have a PRIMA LPR450 and the electrics seem to have just stopped the buttons dont respond at all,I have changed the plug fuses and tried other sockets,nothing! hope you can help x
We had an electrical storm strike close to our house and now our prima c2012 will not turn on.. it will not turn on with the remote or by manually pressing the on/off button.. is there anything that can be...
you can open the back of the tv and see if it blew the fuse but watch out for the flyback anoid it still holds power if you don't know what that is it the thick red wire that plugs into yhe tube so DON'T UNPLUG IT FROM THE TUBE you will get a big charge and the fuse should be near the flyback and if it still dosen't work the the output IC is probley fried.
Sep 12, 2011 | Prima C2012 TV
Universal remote need a code ? or a remote
Hello
Universal remote code for Prima TV are :-
1019 0165 0116 0167
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK
Jan 19, 2011 | Prima C2012 TV
Need code for Prima tv remote
Hello
Four digit universal remote code for Prima are:-
1019 0165 0116 0167
Direct Code Entry
OK.
Dec 03, 2010 | Prima C2012 TV
I touch the on/off button on the Prima TV to turn
I am sure you had some strong static electricity. The static spark arced to inside of the TV in to the circuit board. Many of the low cost TV sets have poor static electricity protection.
In most cases there is damaged caused by static shock to electronic devices.
Just for curiosity, you can try unplugging the set from the AC mins and plugging it back in to do a simple reset, in case there is no damage and some logic device became hung up.
Last year I picked up my mobile phone and got a static shock from it. I had to get a new phone. This phone never worked again!
Jerry G.
Jan 19, 2010 | Prima C2012 TV
Sears Craftsman Gar. door opener won't respond
There isn't a fuse. You are going to need to remove the cover on the opener and find out where you are losing the power. Maybe a neighbor has a volt meter you could use. I would check the power cord and then the logic board. Makes no sense but I would check for burnt or missing traces on the printed circuit board especially around that small transformer.
Aug 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kaito 1103 Shortwave Radio
I dont have this radio but I remember reading that you push the volume button then turn the tuning knob to change the volume.
Sep 23, 2008 | Kaito KA1103 SW/FM/AM Radio
Prima combo tv does not come on when the power button is pushed or even with the remote
check the fuse first then, resolder the power supply of your tv.
Jun 20, 2008 | Prima CV1311 TV
Prima LPR 600
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No HEat Dry" button for 4 seconds (or more.  Try this.
Dec 27, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
LG LDF9810ST Built-in Dishwasher Logo
24 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
