Question about Cycling
I have a 1998 Huffy 626 12-speed. When i turn the pedals all the gears move but the rear wheel doesn't. No matter what speed/gear ratio it's in the chain just spins freely without engaging the wheel. What could it be? Thanks!
  • 456 Answers
It sounds like the ratchet mechanism has failed in the freewheel sprocket on the wheel.
Posted on Apr 06, 2011
Pedaling bike but wont move
Perhaps there is a gear with stripped thread where it attaches to the sprocket or the sprocket itself with stripped thread? In any of these cases, the whole sprocket should be replaced and in the second case the sprocket and hub. This accounts only for 6 or 7 gear sprockets.
Apr 19, 2014 | Huffy Cycling
The pedals will turn but the wheel does not
The rear set of gears, called the "Freewheel" are shot, and need to be replaced. You can find another wheel, but this will probably prove to be difficult, or you can pay for a new freewheel or your bike shop may give you an old one for a discount.
Good luck
Joe
Aug 29, 2011 | Cycling
How is the "ten speed"
I am answering, but hoping this is not a trick question. ALL Bikes from that time period had two shifters, one the speed gears and one to represent the Hi-Low Function of the gears. In other works, when shifter one was move, it moved the chain on the front sprocket to the Low Gear ratio, Which would translate on the rear 5 piece sprocket as gears 1-5. These were change by slightly moving the second shifter, which in turn would move the chain a slight bit and onto the next sprocket in the line. You could go in any combination of gears from 5th to 1st from 1st to 6th, all by moving the correct level, which would move the appropriate chain guide and mode the chain to the correct sprocket. Let me know if that helps at all. I tried to remove the technical in order to keep it simple. I can make it harder and more technical if you would like.
If you are trying to get to a certain answer, please do not hesitate to ask any question, other than where to get parts, cause that part of Huffy's business is no more and Huffy, really isn't the same Huffy as was in 1989. No really, different organization all together, they basically sold the name and ops.
Jun 30, 2011 | Cycling
I'm new to multi gear bikes..whats the reason for the 6 gear positions on the right and 3 gear positions on the left hand side
Bicycles have two sets of gears (front and back). The 6 position control slides the chain between the 6 sprockets (cogs) on the back. The 3 gears are for the front set of cogs. Between the two sets of sprockets, you get 18 (theoretical) different rates of chain movement per turn of the pedals. In fact some of the settings overlap. (However some of these should not be used. Do not use the settings that pull the chain to the furthest inside of one derailleur and the furthest outside of the other. This diagonal between the biggest and biggest sprockets (or smallest to smallest) puts extra strain on the chain.) The back derailleur is in the lowest gear when on the biggest sprocker. The front low gear is on the smallest cog. The highest gear possible is on the smallest rear cog and the largest front cog.
By planning the shifts in gears, you can maintain the same speed and cadence (rate of pedalling) on different terrains. (For going up a hill, use a lower gear than on flat terrain. However don't go to low or the bike may not balance well.) To shift through a large range of gears, you must be pedalling and then move the rear derailleur control followed by the front derailleur then the back again. (For faster shifts to a low speed, you can shift the front derailleur first but that can stress the system.)
For a guide to using the gears: http://www.southcoastbikes.co.uk/articles.asp?article=Gears .
I hope this helps.
May 14, 2011 | Huffy Cycling
My bike does not seem to shift gears should I be cruising as I shift or should I be pedaling
Your bike must not be the Cruiser pictured - that's a one-speed bike. So here's a general description--- For gear changes on multi-speed bikes, where the chain has to move between different size sprockets, the chain must be moving in order to shift. So, yes, you have to be pedaling, but it works best if you pedal very lightly - so that the chain is moving, but is under very light pressure. On the other hand, if you have a 3-speed bike where the gear changes take place inside the hub of the rear wheel, the wheel should be moving, but the chain should not - so you should be coasting to change gears.
Jun 23, 2010 | John Deere Nirve Model Cruiser Bike
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
I insralled training wheels, but now the chain does not move, why?
I'd look for unwanted contact between the hardware attaching the training wheels rear wheel nuts and the chain, wheel, gear or tire.
I suspect a screw is a tad too long.
Apr 06, 2010 | Huffy 16 In. Girls Dream Journey Single...
Bought a Huffy 26inch magellan 700c mens commuter Bike from Kmart there was no manual having trouble figuring out how to get it into various gears, is there a manual I can down load.
just move the gear levers, but keep pedalling forward while you do. you cannot change gears while the bike is stationary and do not pedal backwards while changing
Apr 06, 2010 | Huffy Newport 26 Men s Comfort Bicycle
I just received a sports bike for ecercise and model number is EDG 329u. Every time I try to ajust the peddal speed it makes a weird noise and It will not move the speed it stays the same speed. It is very...
You have the bike in a high gear. Assuming it is a deraleur type, look to see which sprocket the chain is riding on. If it is one of the smaller sprockets (on the rear wheel, not the pedals), put it onto a bigger sprocket by changing gears to one of the lower gears. As a side note, professional riders change gears many, many times during one outing. They keep the pedal speed at a comfortable speed no matter how fast or slow the bike is going. Anyhow, to review, put the bike into a low gear, particularly when starting out from a stop. If the bike makes a wierd clicking sound, or the gears don't change as they should, it is possible that your indexing in your gears needs some adjusting, or there is some other problem. Any bike shop will take care of you, as these are very easy to fix.
Nov 25, 2009 | Cycling
Cycling Logo
333 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
