Question about Compaq Presario V4000 Notebook
Compaq Presario V4000 (v4118AP) right hinge broken
My Compaq Presario V4000 (v4118AP) laptop's right hinge (matel) is broken. I checked the maintenance guide, it list the part no 403922-001.
I want to know, can it be replaced at home? Or does it require some special tools (welding etc) to fix it?
HP/Compaq service center directly said to replace the entire LCD (costing 15000 INR).
Laptop works fine as data/power connector is in left hinge.
Any suggestion/help is welcome.
Thanks,
Nirav
India
  • 1 more comment
  • tray6122 Aug 30, 2008
    To neo_nirav
    I also have that broken part. Have removed it and am now trying to find a replacement. I can tell you steps on doing that job.
    Pat T.
  • joedkill Sep 11, 2008
    I have the same problem with both hinges. Can you help with that?
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
http://www.pchub.com/uph/laptop/291-29919-6327/Compaq-Presario-V4000-Series-Hinge.html
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Posted on Sep 01, 2008
  • Rick Jul 26, 2011
    I got the P/N for my hinges from the HP web site. I used "live chat" as my model was not listed, and got the answer within a few minutes. When I removed the screws from the bottom, I learned that no only those marked with a triangle but one on each side just inboard from the outside marked screws should be removed to avoid working below to remove the hinge screws. It did not appear that the screws (phillips on my unit) inside the battery compartment needed to be removed, but they seem to be marked and it doesn't hurt. I left the cable to the power switch panel connected and folded the panel onto the keyboard during my work.
  • 32 Answers
I bought a pair of hinges from Ebay for the V4000. They were different than my V4000 so be aware of that.
You have to remove the 6 rubber circle bumper discs from the screen bezel to access the screws that fasten the bezel to the LCD. Be careful removing it. Wiggle it and pry gently one way or another until it snaps off.
The hinge covers fit into the LCD lid and their mount holes fit over pegs in the lid.
That's the details for the LCD end of the hinges.
I gave up trying to find the right hinges and covers so I and drilled and pinned the broken hinge.
Posted on Sep 12, 2008
  • Rick Jul 26, 2011
    I just replaced the hinges on my V4000. A thin putty knife made the screen bezel removal pretty easy, although the bottom left corner was the sticky point for removal. Replacement worked in the opposite direction - start with the top edge, down the sides and then the middle of the bottom. Finally work it around the hinges. When replacing the screws I found one brass insert had broken off. To examine behind the LCD, remove the hinges, lay it flat and 4 more screws at the bottom. CAUTION, do not touch the area behind the screen at the top.
Install the hinge covers compaq presario v4000
REMOVE OLD HINGES THEN REPLACE NEW ONE SIMPLE.HOPE YOUR GOOD AT SOLDERING FOR THE SILVER PLASTIC!!!!!!
Jan 22, 2012 | Compaq Presario V4000 Notebook
Would a compaq presario v2000 screen be compatible with a compaq presario v4000 laptop. one of my cats juped onto my closed laptop and now there are two big black blotches and cracks across my screen so im...
Its not compatible. It has different screw listings then V4000.
If you could provide me the product No. which is at the bottom sticker of the notebook of your Compaq v4000 laptop then I can find the part no. for LCD screen which is less costlier and exchangeable.
May 31, 2010 | HP Compaq Presario v4000 Notebook
Cd not reading in v4000 presario laptop, problem w...
cd not reading in v4000 where are there totally free downloads for driver
May 19, 2010 | Compaq Presario V4000 Notebook
Compaq presario 2700, right hinge broken
You can buy hinges on Ebay. Make sure u get the hinge not the cover or support plate. then you have to take it apart and replace it. Not real easy but can be done by amature. Let me know if you need instructions. Be happy to help.
Mar 29, 2010 | Compaq Presario 2700 Notebook
How do i reset a password on my Compaq Presario
Control Panel--> User Accounts--> Create/ Change Your Password
Nov 06, 2009 | Compaq Presario V4000 Notebook PC
Were can i get drivers for my compaq presario v4000?
On Following link you can download Driver for your Laptop.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=461884&lang=en&cc=us&prodTypeId=321957&prodSeriesId=434656&taskId=135
Thanks.
Oct 14, 2009 | HP Compaq Presario v4000 Notebook
I have a compaq presarion v4000 series laptop
yes it can be repaired it will cost between 40 and 150 depending on where you take it
Sep 19, 2009 | HP Compaq Presario v4000 Notebook
Right hand hinge broken
Buy replacement hinge assembly & replace. Quite a simple job & shouldn't take any more than 20 minutes to do.
Aug 17, 2009 | Compaq Presario V4000 Notebook
Want to replace 2x 256mb of memory with 2x 512mb of memory into my hp compaq presario v4000
Hi there.
Yes you can upgrade the memory to 2 x 512MB DDR SDRAM memory.
You will be pleased to know that the system supports up to 2GB DDR SDRAM memory (2 x 1GB)
Please be gentle when installing the new memory taking care to remove the battery and the mains power from the laptop first before installing.
Have fun and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq Presario v4000 Notebook
Compaq Presario V4000 Notebook Logo
3,722 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
