Question about Altima Technologies AGR38PF Grill
I want to convert my agr38pf grill to propane is there a conversion kit / where is the orifice located
    Brigadier General:
  • 4,736 Answers
Actually, there are no conversion kits available from Sure Heat, the manufacturer of your Altima grill. They are manufactured and sold only by the fuel type - Natural Gas or Liquid Propane Gas. So, just changing the orifices is not going to make a full conversion. For more insight, here is a link to the Owners Manual for your model grill. http://www.sureheat.com/Manuals/Grills/altima_manual.pdf
Posted on Apr 06, 2011
I have a Weber Silver B grill that I purchased 12 years ago.I would like to convert it from propane to Natural Gas. I have been told I cant! Is this true? If not, where can I get a conversion kit? Thanks!
Weber stopped selling conversion kits due to some legal action in 2008. There are no longer kits available. What you would have to do to covert it is order a replacement gas valve for the NG version of your grill just to get the orifices. Then you have to replace the LP regulator with a NG regulator. Typically most NG grills do NOT have a regulator but local building codes will require a NG regulator and a different gas line hose.
Conversion of a BBQ gas valve to NG is a matter of drilling out the orifice to a larger hole in an LP orifice.
You will not find anyone that will perform this conversion for you due to legal liabilites.
If you want to convert it... you will either have to order the whole gas control valve for NG or drill out the orifices yourself in your current gas valve hoping your got the orifice hole size correct when you drilled it. Mind you all liability for doing this lies solely with you.
This site has all weber parts:
http://www.clagrills.com/allgrillparts/weber/weber-models.htm
http://www.clagrills.com/gasgrillparts/weber/weber-gas-grill-parts-home.htm
Thanks for choosing FixYa,
Kelly
Apr 29, 2011 | Weber Genesis Silver B Grill
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Converion kit to natural gas.
I don't believe Weber makes a gas conversion kit for your model grill. I say this, because your model grill comes two ways, Natural Gas or Propane. This indicates to me, that there's more than just changing the burner orifices involved.
I can tell you this ... If you could convert it to Natural Gas, you would soon discover that the grill doesn't preheat as fast as with propane. Nor, will it maintain heat as well as propane, in an outdoor environment. Propane burns cleaner and hotter than Natural Gas in an outdoor environment.
Sure, it may seem like a hassle to refill and change the tank, but I can assure you, you won't be satisfied with it's performance.
Feb 03, 2011 | Weber Spirit? E-310 Propane Grill
Dear sir i have a empire/corcho 1500 btu heater and i have a 70 gallon tank of propane tank but the heater says natural gas can i do this or do i have to use a conversion kit and do i do that and where do...
First off, yes you can convert it to propane. The difference is that the orifice, which should be in the conversion kit, has a smaller hole for the gas to pass through and needs to be changed. Secondly, the air consumption on propane is greater than that of natural gas and for that reason you need to open the air venturi, usually to the max to allow the largest amount of air to enter. Don't overlook the pilot light as well, it also needs to have a different orifice installed. You can find new orifices and/or conversion kits at the store where you buy your propane, assuming it's not a big box retailer. Go to a local propane supply location for the parts. Another option is to go directly to the manufacturers home page and order the propane orifices.
Oct 04, 2010 | Reddy Heater RLP100 Portable Forced Air...
How do I reconvert my Natural Gas BBQ BACK to LPG?
You will need to replace the nat gas orifices with propane ones, as propane orifices have smaller holes than nat gas ones. If you can't find a conversion kit for your grill, take it to a local propane co and have them convert it for you. What I do is drill out the existing orifices on the grill and install a spud, then redrill the spud with the smaller hole for LP-Gas. Then you will need to buy a regulator and hose and a 20# propane cylinder, if you don't have one. You can get those things from the propane co too. Call around first and see if anyone can help you.
NOTE: If your grill data plate isn't marked with the BTU rating of each burner, look at the nat gas orifices and see if there is a number stamped on it. I can reference this number to tell you what BTU rating they are drilled for and use that to redrill for propane. If they are not stamped with a number, then I would use my nat gas orifice drills to gauge what hole size it is. Hopefully you can find a local propane co that carries these orifice drill kits and orifice spuds to get the job done. You didn't mention the grill brand or model #, so I can't help with specifics until I know what you have. I may be able to find a conversion kit online if I knew that info.
Douglas
Jun 13, 2010 | Grilling
Converting weber natural gas grill to LP Gas
You will need to replace the orifices and install a propane regulator and hose. Plus, of course, you'll need to buy a 20# cylinder. I looked up your grill serial # and found a parts explosion for your grill. Here is the link: http://www.weber.com/PublicSchematic/view.aspx?model=6821001
If you click on the "additional parts" link, they have the conversion kits listed, but none of them are available anymore. As a propane guy, your best bet is to take it to a local propane co and have them convert it to propane for you. They will drill out your existing orifices and install spuds, and then re-drill smaller holes for the appropriate BTU rating for each burner. Then they can install the regulator and hose and even sell you a new and full 20# cylinder. Call around first and see which one can help you, as not all have serviceman that can do this particular job. Hope this helps. Douglas
Jun 06, 2010 | Weber Genesis Silver B Grill
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
I have a Sunjoy patio heater that uses propane and I want to convert it to natural gas. Is there a hose kit, and do I need to change the orifice. Richard
You will have to change the orifice for sure, but you have to get an orifice that works with the valve on the heater. Check with the manufacturer and see if there is a conversion kit, it is the only way to make sure that you make all the necessary changes to the unit. If there is not a conversion kit available, I would recommend that you not do it.
Nov 19, 2009 | Grilling
Altima Technologies AGR38PF Grill Logo
235 people viewed this question
Top Altima Technologies Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you an Altima Technologies Grilling Expert? Answer questions, earn points and help others
