Question about Vacuums
YPD MOSQUITO BAT IS NOT HAVING SUFFICIENT VOLTAGE AT IT'S NET TO KILL MOSQUITOS.PL. GIVE REASONS
  • 2,510 Answers
Battery voltage low? To test a battery you need to place a load on it to get the true reading of the power left in it. A straight test with a volt meter at no load is a misleading indication and will almost always give the battery rated voltage, even though the battery is almost dead.
Posted on Apr 06, 2011
My wire has come loose at the handle part of my dc07 as my machine keeps turning off when I catch the lead
That's dangerous stuff. Get a certified appliance tech to sort that. I give advice on stuff that won't kill you only. If you need to ask this question then you should not be fixing it. Sorry.
Keith from Dyson Repairs North Shore
Sep 23, 2014 | Dyson Pre Motor Filter DC-07
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Getting an H97 error code on a Panasonic micro wave, I believe I am having an inverter problem
Troubleshooting of Inverter Circuit (U) and Magnetron
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
NOTE: DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Alternative way to troubleshoot oven with AC Ampere meter used. H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
Hope this helps.
Apr 28, 2011 | Vacuums
Need diagram to replace cord thank you
I'm sorry, but diagrams for these machines are only available to the owners and service techs at Aerus Electrolux stores. No hard copy, and nothing on the net.
I don't recommend doing it yourself anyway, for the following reasons.
1. risk of breaking tabs.
2. unable to reassemble correctly
I strongly recommend taking it to your nearest Aerus Electrolux store.
http://www.aerushome.com/storelocator/
Mar 04, 2011 | Electrolux UltraLux 2000 Bagged Canister...
MY ASUS PHONE, Touch screen is broken.Pl tell me some ASUS service center in Ghaziabad,U.P.,India
Go to the site listed below for addresses to the nearest service centres to you. Please do not forget to rate the answer I give you.
http://asuspartner.in/BranchesAndFacilities/aboutasus3.htm
Dec 26, 2010 | Vacuums
My ceiling fan lights flicker, whether or not they are dimmed. Can this be fixed?
Surely this is the fault in the controller circuit. possibble that the thyristor which is the switch and voltage regulator is not working correct. The bias to the thyristor is not sufficient to keep it in correct mode. Can be the thyristor itself or the bias circuit.
Aug 30, 2010 | Vacuums
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
Will not dispense water
There are many reasons for this. Most shops give free estimates. Give one a try.
Oct 09, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Battery charge
Dave you are correct. You should never over-charge anything like a Roomba, Cel Phone, etc. That will kill a bettery very quickly.
Jan 11, 2009 | Roomba Robotic Floor Bagless Vacuum
Vacuums Logo
220 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
