How do I replace the right hinge on the lid of a Sony Vaio PCG-6Z4L?
  • 25 Answers
That link for the PCG-K series is no good (e.g. a site for how to take apart an printer would be just as useful; sorry Martin Murray).
I have the same laptop as you (PCG-6Z4L), couldn't find a site. Like most laptops, it's about getting all the screws out and then being gentle with the plastic barbs (spudger or fingernail helps). In our case, there's only one hidden screw, discoverable by taking off the memory plate. The other tricky part is separating the top most plastic keyboard/palmrest assembly from the rest (then your on to getting at things like the hinge).
I've attached a pic so that you can see your laptop in two pieces (i.e. that part of the lighter grey stays with the darker grey; again, spudger or fingernail and knowing the two separate should help).
Posted on Jun 12, 2012
    President:
  • 1,623 Answers
Although this isnt your exact laptop i would follow this guide from step 1 to step 11 to remove the screen
http://www.insidemylaptop.com/disassemble-sony-vaio-pcg-k-notebook/
Posted on Apr 06, 2011
A part of the outer case my PCG-61411W Sony Vaio laptop is broken at the place of the hinge, how can I replace it ?
See if you can find a bottom case and lcd hinges on ebay.
http://www.ebay.com
Just put in your computer's make and model in the search box.
Example: Sony Vaio PCG-61411W bottom case or Sony Vaio PCG-61411W Lcd Hinges
Jun 02, 2012 | Computers & Internet
The battery charger of sony Lptop VAIO PCG-7T1L has become faulty, i m not able to get a support fron sony service center, so how to purchase or get it reapired in Delhi
can just buy a replacement in the link below
http://www.ebuybatteries.com/product/GBProduct.asp?id=973M69&item=Sony+VAIO+PCG-7R2L+PCG-7T1L+PCG-7V1L+ac+adapter+laptop+charger
Feb 26, 2011 | Sony VAIO PCG-7T1L Series Laptop Charger...
I need to replace my hard drive in my Viao PCG-GR370 laptop. Is it possible to put in a larger than 30 GB drive?
below is a link for a 320 gig hard drive for your model, i hope this helps
http://www.upgradecomputermemory.com/ram.cfm//memory/s/sony-vaio/sony-notebooks-vaio-pcg-series/VAIO-GR-PCG-GR-Series-Notebook/VAIO-PCG-GR370/320GB-Notebook-Hard-Drive-for-the-Sony-VAIO-PCG-GR370.html
Feb 14, 2011 | Sony VAIO GR370 Notebook
How do you remove the hard drive from the pcg-6z4l Sony Vaio?
Remove the bottom cover. Make note where are each screw located because they're different.
After you removed the entire cover, you'll have access to the hard drive.
The screws you need to remove have an arrow mark.
Nov 08, 2010 | Computers & Internet
Hi . is vgn sz430n the same as PCG 6Q1L ?? I
Yes, VGN-SZ430N is similar to the PCG-6Q1L.
The only difference between the two coding is that the first one is the model # of the Computer used by the technical support team or sales support team for providing assistance however, the later is the Hardware configuration code of the Computer that categorizes a few models.
Oct 01, 2009 | Sony VAIO VGN-SZ430N/B Notebook
Help me please
PCG-5K7B is a General model # of a VAIO Computer.
To locate the exact Model # of the VAIO Computer:
Option 1:
You can find the model number of the VAIO Notebook on a small label located either on the bezel of the LCD display or on the LCD hinge or at the top left or top right of the keyboard. Try to locate the model number that starts with PCG or VGN continued with alphabets and then with numerical values.
Option 2:
You may also go to START menu and click on 'RUN' option and enter 'msinfo32' to locate the exact Model of your Computer.
Or
Please goto Start Menu, select 'All programs', select 'Accessories' to access 'Run' option.
In RUN command window type 'msinfo32' and press the Enter key to open the System Information window to locate the Model # of the Computer.
NOTE: Your Computer model # may start with VGN-CR and then with numerical values.
After getting the model #, visit this Link to get the drivers for your Computer. Select the Operating System to download the drivers.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
Good Luck!!!!!!!!!!!!!!!!!!
Sep 16, 2009 | Sony VAIO PCG-K23 Notebook
Screen on Sony VAIO PCG-SRX99 needs to be tightened.
you will have to take the bezel front plate of the screen off and check to see if anything there has broken from the hinges. there are usually two-three screws holding the hinge to the screens back cover and two-three holding it in place on the base of the laptop. if all those are intact you will need to replace the hinges.
good luck
ruben
Apr 06, 2009 | Sony VAIO SRX99 Notebook
DRIVERS
What Your Actually looking For Are Drivers For The:- VGN-FS485B.
So many people get confused, with Sonys Model And Make Numbers.
Theres usually 1 located Underneath The Base of the Laptop, And 1 On the lower right/Hand/Side Of The Screen Or hinge Cover. ( Differs On Newer models )
The Number on the Screen/Hinge Is usually the Actual Number to search Drivers/Parts et,c For.
If you Go here:- http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&c=0&s=VGN-FS&m=2203
This should lead you to all you require.
Mike @ Compurepair.
Feb 28, 2008 | Sony VAIO VGN-AR230G Notebook
How can I remove the hard drive from a Sony VAIO PCG-F305?
Remove the keyboard also,there's usually some more screws under the keyboard.
Oct 17, 2007 | Sony VAIO VGN-S460 Notebook
Computers & Internet Logo
181 people viewed this question
David Payne
David Payne
