Question about Toshiba Computers & Internet
Sudenly my laptop did not work and it said there is not hard drive in it what can be this?please help
    President:
  • 1,623 Answers
Either your hard drive is damaged or the interface is , the only way of determing which it is, is to install a new hard drive that you know is working in the machine and see if it detects it
Posted on Apr 06, 2011
  • Toshiba Master
  • 6,771 Answers
If the hard drive has completely failed the motherboard will not detect it, remove hardware and re-seat it back in position, sometimes this is enough to restart the hard drive, if this fails the hard drive should be tested before replacing it.
I have the dell inspiron 1525 since september 2008.Sudenly an hour ago the screen light is out.Whatever i tried no solution.My pc works perfectly nevertheless but i have to use a big spotlight to light and...
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 06, 2011 | Dell Inspiron 1525 Notebook
Hi, im having problem with my hard drive, dell inspiron 1525. when i boot my laptop i got this message " to resolve this issue, try to reseat the drive". I badly need your help. thank you
The laptop is having difficulty connecting the hard drive. The hard drive may be faulty, but you don't know until you re-seat the hard drive.
Remove the hard drive from the laptop and insert it back, do this a few times to ensure the hard drive makes proper connection to the laptop's motherboard and then boot up the laptop.
If you are still getting this error message then you probably have a faulty hard disk, then this need to be replaced and Windows installed on the new hard disk with the Dell laptop's device drivers and your programs to get a working laptop again.
Please let me know how things turn out.
Oct 30, 2010 | Computers & Internet
Opened laptop to find ' internal hard drive not found ' i did a reseat on hard drive , still not working. ran f5 test and tests all ok bar hard drive not found. laptop was working 10 mins before error came...
Please make sure if you open the back part of the laptop check the Harddrive if it is firmly connected. bacause it is possible that the reason why the laptop doesn't detect it is because of the physical connection.
Oct 01, 2010 | Dell Inspiron 1545 Notebook
I was wiping the hard drive when the laptop
Please come back to us with the exact error if you get any.
However, how you are performing recovery. Using recovery manager or recovery discs?
If you are using recovery manager, please perform hard drive self test and check with the result.
Hard drive self test steps:
1. Turn Off the notebook.
2. Turn ON the notebook and keep tapping F10 key
3. Once you are in BIOS, navigate to tools/diagnostics tab with the help of left and right arrow key.
4. You will find Primary HDD self test or HDD self test.
5. With the help of up and down arrow key select the respective test and hit enter.
6. Short test will take only 4-5 minutes. However, long test may take 40-60 minutes.
If the hard drive is fine, try to perform recovery using recovery discs....
If still the problem exists try with different discs.
If the hard drive fails replace the hard drive.
Hope this will work for you!!!!!!!!!!!!!!!111
Mar 17, 2010 | HP Compaq Presario V2000 Notebook
I have Toshiba A355-S69253. Laptop got frozen when I tried to log in to Internet. Then all of suden, the display went off. It is blank, but the power is on.
Please see this FixYa Tip which adresses this exact problem with the Toshiba laptop. If the solution works then please do take a moment to rate it.
Thanks for using FixYa.
Nov 28, 2009 | Toshiba Satellite Pro L300 Notebook
I own a Hi-Grade Via 14'' (VE8569)Notebook and until last night haven't had any problems with it - but for some reason when I turning it on, I am getting a black screen with the following message: Intel...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty.
First - re-seat the hard disk and reboot the computer. if this does not work then reboot and go to the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Next - to determine if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and you cannot open the various folders and files, this confirm the hard drive is faulty.
The hard drive needs to be replaces in the laptop and Windows installed and the laptop's device drivers and your programs etc to get a working laptop again.
Oct 29, 2009 | Computers & Internet
My cd rom used to work perfectly.sudenly stoped.the icon doesnt come up in My Computer and doesnt read any cd help please!
According to your issue as you are not able to work with your cd rom and as you have not mention what operating system you are using if its windows then its known issue from Microsoft so try the following website it will help you up in case of windows computers
http://support.microsoft.com/kb/314060
Regards,
Om
Oct 19, 2009 | Acer Benq 16x DVD and 40x CD-ROM Internal...
Can i repair hard drive??
if the hard drive is not detecting then it may be the problem of the card of the hard drive it can be changed and repaired , other things are not easy
Jun 13, 2009 | Seagate Momentus 5400.2 120 GB Hard Drive
Seagate 250GB FreeAgent USB 2.0 Ext Hard Drive with laptop
Whether your computer is a laptop or desktop does not inherently decide if the drive will work or not. If it can't see the connection, there must be another problem with the drive. I would suggest reporting what you have done to try and make it work and anything you notice out of the ordinary (how lights on the drive are acting, noises the drive is making, alerts you see when you plug it into your laptop, etc). That will allow us to better help you find a solution to the problem.
Feb 19, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hard drive
Please get a SATA Hard Drive. Its compatible with your laptop mode. Dont forget to mention the model no. of your laptop before buying the drive. You will get it from Bestbuy.
Thanks
Oct 13, 2008 | Panasonic Toughbook 48 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
