Question about Akai PT50DL24 Television
TV won't turn on. But my model code is a little different it is PT50DL14X/SMS
  • 10,594 Answers
Please replace lamp in tv to solve the problem.
This has been discussed in chat session a while ago and you found broken lamp in tv.
Thanks.
Posted on Apr 06, 2011
Akai pt50dl14x sms
Linda .....no its not the lamp thats causing the whirring/buzzing sound but the colour wheel, its housed in the light engine you will need to replace the whole light engine cos the inbuilt colour wheel is worn out this causes the buzz hence the lamp may not light up or u may have shut downs flickers on the pix or color issues
Jul 08, 2013 | Televison & Video
Vivo tv won't turn on lost the remote and the
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
Jan 23, 2013 | Televison & Video
Tv won't turn on. All three lights flash in sequence power heat then bulb. The bulb appears to be in tact.
I will need the model number of the set in order to assist with the issue as the three lights blinking is an error code which would be different based on which model number TV you have.
Oct 30, 2012 | Hitachi Televison & Video
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Jun 09, 2011 | Televison & Video
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Jun 02, 2011 | GE GTD120 System
Akai DLP projection TV. Picture is fine except lamp is not illuminating a 3-4in area on the left side of the screen. You can see the picture over there but it is dimly lit. I can't seem to find a way to...
The problem is the light tunnel is collapsing. This is a VERY common issue with the Samsung/Akai DLP TV's. It is four mirrors used to transfer the light after it passes the color wheel to the DMD board. When part of it collapses the grey bar that you are seeing is the end result. This is a part that usually requires a technician to replace as there is a little tear down of the light engine itself and you would be handling delicate parts. The part number for the tunnel assembly is BP96-01961A and I have included a link so you can purchase it through the Samsung website. Please take a few moments to rate my answer. Thanks..
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96-01961A&search%5Fmodel=PT50DL14
Nov 20, 2009 | Televison & Video
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
HELP!!!
I think i have the solution to your problem,
I think that the lamp has gone out in your tv. You should try changing it out. I work with many tv's with DLP's and it almost always is the lamp. YOu can order it online, there is a slot on the side of the tv were you can change it out through there, the lamp should have a number on it. And its pretty simple to do. So there you go..and I could have gotten you a better deal on your Tv.
THE END
Jun 28, 2008 | Akai PT50DL24 Television
Akai PT50DL24 Television Logo
185 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
