Question about KitchenAid Refrigerators
LIGHT BULD IN REFRIGERATOR BURNED OUT. NEW BULB DOES NOT LIGHT EITHER
  • 17,970 Answers
I suggest use a voltimeter and check for power to the bulb receptacle. If no power, remove and test the door switch.
Keep us updated.
Posted on Apr 06, 2011
I have an LG fridge model GWL227hbya. the light build in the fridge had blown so i replaced the buld with original replacement part.
The bulb socket may have corrosion on contacts. Disconnect all power to unit and then clean out contacts to restore operation. Make sure that bulb is also fully inserted.
Aug 24, 2017 | LG Refrigerators
Bulb gone
its a 15w appliance buld small screw type you can get one from b&q or local domestic appliance shop just take your old bulb with you then you will get the wright one pop light cover off unscrew bulb they somtimes put have a philips screw hold on the cover
Nov 27, 2011 | LG Refrigerators
I own an InFocus Litepro 570LS. The projector light bulb blinks on and off.....I do not know how many hours are on the buld and the spare buld is burned out....what is a possible fix.
Given that the bulb actually lights up and then goes out you need to check the contacts at the base of the socket to ensure proper contact is consistently made at the base of the bulb. Be sure to unplug the projector prior to inspecting and adjusting.
May 17, 2011 | InFocus LitePro 570 LCD Projector....
The bulbshead lights keep going out,
If you are replacing the headlight bulbs and just a short time their bad again you need to change your techniquie in installing the bulbs. You can't touch the lens of the bulb with anything ( not your finger) or the bulb will overheat in operation and burn out. with the old bulb out and the pulg laying out to where you can get it or someone else holding it. Open the package the new bulb comes in so just the plug end sticks out of the package. holding the bulb by the package install the buld into tne socket and them hold the socket only to put it into the back of the headlight with out running into any thing as touching anything can cause the buld to fail/ If the light fixture is getting water or dirt inside of it it will need to be repalaced.
Mar 04, 2011 | 2004 Hyundai Elantra
Replaced a dlp bulb and it smells like it is burning
Did you clean out the area where the bulb goes, and did you touch the new buld with fingers, or is the new bulb the correct bulb? All these are questions I would ask myself first, then if all are good, then in the bulb area there could be some other problem
Feb 18, 2011 | Televison & Video
Installed new low beam headlight and light will
Hi, if you have a meter to check the bulb, use it to check the wiring to the socket or wiring for power when light switch is turned on. You should have around 12 volts depending on year and type of truck or auto. If the old bulb was burned, you should have power there. When you turn on switch, the other side should work and you will know you have power and it may just be corroded. Check this and you should find the problem. Please keep me posted on this, I will be around to help you. Please rate me kindly if I have been of help to you.
Sincerely,
Shastalaker7
Jul 06, 2010 | Chrysler Town and Country Cars & Trucks
Light issues
lights are controled by the light sw . ck them or replace them . / some times the lights are not in tight. remove the light and use some pam on the base and reinstall . if buld is good .... mm
Apr 18, 2010 | Amana ATB1832AR Top Freezer Refrigerator
GE GTS20ICNCC Refrigerator light bulb burns out quickly
Use the correct wattage bulbs. If they fail often then you may need to get it checked by an electrician.
Filament bulbs easily burn out. What you can do is to buy cheap bulbs and replace as soon as they burn. This is the problem which is why tube lights and LEDs were invented!
Sep 07, 2009 | GE Refrigerators
2 out of 3 brake lights not working
Check the connection, where you put the bulds in, it might be missing the metel connection. that happen to me before.
Jan 16, 2009 | 1998 Dodge Neon
Light bulb
Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
Jun 19, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
90 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
