Question about Dell 1110 Laser Printer
My dell 1110 printer is making a loud clicking noise
SOURCE: Dell All-In-One 948 InkJet Printer
This might not be the issue but I had a similar problem when I first got the printer. Open the top-( where the ink is loaded), look at the back on the right there is a small bus cable ( flat wire usually white) make sure it is pulled in all the way into the top. Be carefull as the prongs can break. This took care of my clicking clacking when the machine came on.
Good luck
Posted on Feb 05, 2009
SOURCE: MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Posted on Aug 04, 2009
  • 8 Answers
SOURCE: Printer jams but no paper jamming. I have to pull
clean and check your paper pickup roller.may need cleaning and or the roller may need fixing or replacing.
Posted on Oct 16, 2009
  • 65 Answers
SOURCE: Dell 1110 Laser Printer Fuser Error after
I would if it will print I would try a laser printer cleaning kit canbe found at any office supply like office max or staples
Posted on Jan 09, 2010
jmgldsmth
  • 1889 Answers
SOURCE: Printer making a loud clicking noise when printing.
the feed roller gear is stripping; remove the cover and, adjust the gear retainer before it completely fails. (it should be easy to see the gear once the printer cover is removed.
Posted on Mar 30, 2010
What causes a loud grinding noise when I print?
Howell310,
Can you provide the model of the Dell Printer you have that is making a loud grinding noise. I can the search for resolutions to this issue.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 27, 2016 | Dell Office Equipment & Supplies
Can not print envelop with Dell 1110 Laser printer.
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
restart the computer:
  1. Click Start and then Shut Down.
  2. Click Restart.
    The computer restarts.
Nov 02, 2010 | Dell 1100 Laser Printer
I turned on my Dell 1110 printer and it keeps making the same noise over and over. The top "rollers" keep moving and I am not printing anything. I had to turn off the printer because it was getting so...
It does have a high pitched noise when it first starts up that is annoying, but after a few minutes it stops. If the roller is keep moving and non-stop, maybe you should contact dell.
Aug 20, 2010 | Dell 1110 Laser Printer
Mar 30, 2010 | Dell 1700n Laser Printer
Jan 09, 2010 | Dell 1110 Laser Printer
Dell 1110 won't print
I reloaded the software and it worked.
Thanks
Merrill Millman
Jun 18, 2009 | Dell 1110 Laser Printer
Dell 964 AIO will not work just makes a fast clicking noise.
yes, the old printer has a broken tooth. it is going to cost you the same in repair as to buy a new one.
May 13, 2009 | Dell Photo 964 All-In-One InkJet Printer
Paper is jam on the top feeder of Dell 1110
There is a section in the user guide that shows how to remove and avoid paper jams on this unit:
Click on the user guide link .
http://www.generalmanual.com/Printers/Dell-1110-Laser-Printer.htm
Printer paper jams can be caused from:
Paper that is sticking to-gether - fan your paper from both ends and both surfaces before placing it into the printer
Paper tends to absorb moisture in high humidity - this can also cause it to stick and jam.
Always store your paper flat - many printers jam readily when supplied with bent or slightly damaged paper.
There could be a piece of paper stuck in the printer from a previous jam - especially if you have printed labels - it only takes one tiny corner of a label to cause paper jams in any printer - cheap consumer models to commercial models costing thousands of dollars.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 23, 2009 | Office Equipment & Supplies
Problem with Dell 1110 printer - says it is online
you need to place the printer back online , to do this you need to go to the printer icon and right click , notice the option to USE PRINTER ONLINE select this option.
Feb 09, 2009 | Dell 1100 Laser Printer
Dell 1110 Laser Printer Logo
73 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
