Question about Timex TwoTone Analog Expansion Band Dress Stainless Steel Bracelet T2M935 Watch for Men
Remove links from a t2m935 timex - Timex TwoTone Analog Expansion Band Dress Stainless Steel Bracelet T2M935 Watch for Men
4 Suggested Answers
indays
  • 111 Answers
SOURCE: timex data link band
good morning ! remove the spring bar carefuly to remove the band on your timex data link ! use screw driver to open the case back ! be verry careful to do that ! thanks !god bless !....
Posted on Sep 04, 2008
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
escapement
  • 2334 Answers
SOURCE: How to remove links on womens t26301 watch band
Read my tips, plz.
Posted on Jan 18, 2010
How to remove links from stainless steel link band from ladies timex cr 1215
you need a fine pin punch to do this and most shops that ct keys etc do this for small charge
May 08, 2016 | Timex Watches
How to remove watchband on timex atlantis 100
On this link you can see how to resize and remove the watch band.
You need some tools.
Resize your Watch Band and Remove Links with Basic Tools
Jul 21, 2014 | Timex Atlantis 100 77517 Wrist Watch
My timex indiglo watch's expansion band is too large. How can I remove links to make it smaller.
mcdevito75 here, Removeing the tiny pins to remove links is fairly easy, replaceing them is the hard part, for this you"d need a Link remover tool, Best Bet is to look for a small watch repair shop in your area, the $10--15.00 cost will equal your Time, effort and tool you"d need. Don"t forget to hold onto the links removed from the band in case you need them again.
Feb 09, 2011 | Timex Indiglo Expansion Watch
How do I remove a link from the wristband of my Timex wrist watch, model WR 30 M?
Click on my profile (escapement), then click on Tips and Tricks. There you will find HOW TO ADD OR REMOVE LINKS. Rate me, please
Apr 02, 2010 | Timex Watches
I'm trying to remove a link from my Timex T25771 watch. It has the deployment clasp.
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to remove or add links. Rate me, please
Mar 10, 2010 | Timex Watches
Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
Timex data link band
Aug 29, 2008 | Timex Sports Ironman Triathlon 100-Lap...
Adjust wristband
The solutions already mentioned worked for me. However the first link took me forever to remove as I found it hard to envisage what I what attempting. Attached is a pic of a disassembled link which hopefully might help someone....BPB547b9a0.jpg
Dec 29, 2007 | Timex Ironman 30 Lap 53952 Wrist Watch
Timex TwoTone Analog Expansion Band Dress Stainless Steel Bracelet T2M935 Watch for Men Logo
195 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
