Konica Minolta Bizbub C253
We have now the above printer in our office!
When faxing it does not print a delivery report. Do you have any idea as how to activate this so that we can receive one?
Thanks
Elaine
    Problem Solver:
  • 18 Answers
To output a TX Report after every fax transmission, perform the following:
1. Press the Utility/Counter key.
2. Touch [3. Administrator Setting] on the touchscreen.
3. Enter the Administrator password (default password is 12345678).
4. Touch [OK] on the touchscreen.
5. Touch [7. Fax Setting] on the touchscreen.
6. Touch [7. Report Settings] on the touchscreen.
7. Touch [TX Report] on the touchscreen.
8. Touch [ON] on the touchscreen.
9. Touch [Exit] on the touchscreen to return to the normal copy screen.
Please send posotive feed back if this helps.
Posted on Nov 27, 2008
Konica 7145 say PM fixing unit (Web) won't copy but will print
have tech come out and replace the web roller above the fuser unit, and clear the counter after install. THAT IS LEGACY MACHINE google for the web roller
Jan 10, 2017 | Konica Minolta Konica 7145 Minolta Bizhub...
How do i adjust default tray for fax receiving
Go to your FAX option button on your C253 and paper then chose what tray you prepare to use press OK after to set the default tray.
Aug 26, 2015 | Konica Minolta Bizhub C253 Copier
How do I print a fax confirmation on a Konica Minolta c284E? i AM NOT GETTIKNG A CONFIRMATION PAGE WHEN i SEND FAXES
In your administrator settings you need to go to report settings and activate it to print TX reports. When the machine is standard then it will only print a report if the fax has failed to send.
Aug 26, 2014 | Konica Minolta Office Equipment & Supplies
Error code:P21 and P8
try to go to your printers and faxes it is located in the start menu.
Apr 03, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Printer status report printing on each print in konica minolta bizhub c300
Printer status report, you can turn this off simply go to Printer properties check there.Check in printing preferences option.Also check in your Microsoft Office setting.Printer report printing is turned on simply turn it off.
Jan 10, 2012 | Konica Minolta Bizhub C300 All-In-One...
Konica Minolta C250 Scanner problem
To print the transmission report:
1. Press the [Fax/Scan] key to display the Fax mode screen.
2. Touch [FAX Menu].
3. Touch [TX Report] on the Set 1 tab.
4. Select how to output the report, and then touch [Enter].
– Default: The transmission report is printed according to the previously specified method.
– ON: The transmission report is printed with each transmission.
– If TX Fails: The transmission report is printed only if the fax could not be sent.
– OFF: The transmission report is not printed, regardless of the transmission result.
Feb 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Print Fax Confirmation
The Bizhub C250 accepts the FK-502 Fax Expansion card like most other Konica Minolta Products so this data is relevant for many models. Below are the step to enable fax confirmation pages:
Press the fax button.
Press the Utility/Counter button.
Touch Administrator Setings.
Enter password (12345678) or (00000000) are the defaults.
Touch OK
Touch Report Settings.
Touch TX Report Settings.
Set TX Report to ON.
Close, OK, and/or Exit all the way out.
Oct 31, 2007 | Konica Minolta bizhub C250 All-In-One...
1,504 people viewed this question
jasbo
jasbo
