Question about Cell Phones
Screen has become hazzy due to the fact that the phone was in direct proximaty of the car heater
    Problem Solver:
  • 10 Answers
Dry it by heating through 200W bulb.
did it worked?
tell me. okzz.
Posted on Aug 06, 2008
Wy does the screen frozes and blackberry storm 9530
If your screen is stuck on the Blackberry logo, chances are your software is either frozen or has become corrupt.
Step one would be to attempt to soft reset the phone, by removing the battery out from the back of your device and re-inserting it. Note that Blackberries can take anywhere up to 15+ minutes to load the Blackberry Operating System, depending on how much data is loaded onto the phone.
If a soft-reset did not solve your issue after giving it proper time to load, it is likely that it needs to be hooked up to a computer and have its software wiped. This is not an easy procedure. The video below should assist you in performing this if needed.
Finally, if that doesn't work, you may just need to replace your blackberry by taking it to your wireless carrier's nearest store.
Mar 07, 2011 | RIM BlackBerry Storm 9530 Smartphone
No heat coming from heater. Mechanic said he will bypass the heater core but then I will never have any heat? Any suggestions
If the problem is infact the heater core, it could be very costly to put a new one in, I suggest looking at junk/scrap yards for a used one for your car.
Feb 17, 2011 | 1992 Subaru Loyale
Just had fuel delivered and the heater burner won't start. Probably a bubble in the line?
This is probably due to the fact that you will need to purge the line. Be sure to ventulate the area that the stove is around and make sure you have no open flames while doing so. Also, remember that if you fill your propane tank FULL then it will take a little while for the pressure to build up in the tank because its cold outside.
Hope that helps.
Jan 27, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
Screen is white and won't go back to normal
Hi the problem you have is very common with all flip and slide phones, the exact problem is that the ribbon that carries the info from the circuit board to the screen has worn and become damaged.
Inside the ribbon runs thin copper wires and this is how the data gets sent to the screen giving you the picture, now the reason they use this ribbon is due to the fact the screen moves seperate from the main circuit board so the wires have to be moving, this is the problem over time these wires ware and break and this is what gives you the white screen.
the only way to solve this problem is to get the ribbon replaced, now the ribbon is not expensive to buy and you would also have to pay a phone shop to fit this for you as you need special tools to do this.
your cheapest option would be a local phone shop and not one of the big brands go to someone who has their own mobile phone business and this will be the cheapest way and it should be the fastest way to as they dont need to send the phone off to be repaired.
May 16, 2010 | LG Chocolate Clamshell VX8600 Cellular...
My mobile SGH_E800 Is having camera problem. when i switch on to camera mode a hazzy picture is displayed on the screen.
Feb 11, 2010 | Samsung SGH-E800 Cellular Phone
Anycool T828 - Screen
There are three reasons. The LCD got damaged, change it. The connectors got loose/disconnected due to fall, have them fixed again and the display IC got damaged (hope not) as no one can repair it. The phone is scrapped if the IC goes.
Aug 25, 2009 | Cell Phones
Fuzzy or hazzy displayon view finde and screen
If it is not a setting problems, and if the black and white is only on LCD and not on picture, then it is a problem with the LCD. Probably just the ribbon cable not well inserted into the connector.
Camera must be taken apart to fix this problem. Better to have the job done by a technician at a camera repair shop.
Sep 16, 2008 | Panasonic Palmcorder PV-L452 Camcorder
Hazzy picture
This appears to be a firmware fault - not solvable by the user- Get onto Canon Technical Support Team.
Jan 20, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
