This is in reference to a Staples SPL-TXC22A paper shredder. The ant-jam light comes on when a piece of paper is inserted, and it won't shred. If we hold the forward button on before inserting the paper it will shred and keep shredding until we take our finger off the button. I looked to see if anything was jammed in the feeder blades but it isn't. I swiped the entry slot with a q-tip but I really can't see much of anything. It seems like a sensor problem, but I can't see any sensors, even with a flashlight. There's no place I can see to remove the cover over the blades, so I can't really see down in there. Any suggestions?
SOURCE: Fellowes Powershred 220C shredder.
i am not a service engineer of paper shreder
Posted on May 02, 2008
  • 876 Answers
SOURCE: SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Posted on Aug 01, 2008
SOURCE: Have a Staples SPL-XC200d Paper
I have the same shredder, and was wondering where you add the oil and what type you use? Would mineral oil work? I lost the manual, and I can't find any info online. Did you resolve your issue with the "add oil" light?
Posted on Aug 27, 2008
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
  • 1218 Answers
SOURCE: The shredder developed a jam. I removed the bin
Does the motor run??? even in reverse???
If the motor doeas not run at all it probably PCB. If the motor does run but the cutting mechanism does not turn then you probably have stripped/broken plastic gears... open and check, Royal at 1-800-524-0799 for parts assistance.
Posted on Oct 28, 2010
I have a staples spl-xc200d paper shredder. It runs on auto is that normal
If I understand the question then yes it should run on auto when the paper is inserted to be shredded. I have this shredder as well and mine is always set to auto.
Apr 19, 2017 | Staples Office Equipment & Supplies
How do I put Staples SPL-770M into automatic mode?
Turn it on and insert a piece of paper you want to shred.
Apr 21, 2015 | Staples Office Equipment & Supplies
What lubricant do you use for a Staples SPL-XC240D and where do you lubricate it?
Staples actually sells shredder lubricant. It comes in a small squeeze bottle. You actually are lubricating the shredder teeth themselves to keep them sharp and prolonging their lifetime. You simply take a piece of paper you are about to shred, run a bead of the lubricant across the sheet and feed it into the shredder. Done!
Mar 04, 2015 | Staples Office Equipment & Supplies
Staples shredder parts
You can try cleaning it and maybe limiting shredding to one sheet at a time.
Jan 14, 2014 | Office Equipment & Supplies
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
Staples TXC22A. Why does Jam Light prevent shredding?
Your meticulous cleaning may have overlooked embedded residue from coated paper or paper laminated with plastic. It may be necessary to use a sharp pick and even a utility knife to remove the material bit by bit.
Feb 05, 2013 | Office Equipment & Supplies
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Sep 10, 2009 | Office Equipment & Supplies
SPL 1506X Shredder
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
303 people viewed this question
