Question about Whirlpool Dryers
I have a whirlpool dryer mod #LER5620KQ1 that suddenly went dead. Any ideas on what I need to do?
  • 822 Answers
If plug fuse is ok......id start with motor starter cap....silver can next to the motor..
to see if its the cap..........remove dryer lid.....power up............
then very very carefully................ push the drum..if it bursts into life.....you need a new cap.....
be careful..........good luck
cheers
Posted on Apr 06, 2011
  • Whirlpool Master
  • 8,220 Answers
First thing yall do is check for reasons why the dryer would quit. The most common being air restrictions. I have a whirlpool dryer mod #LER5620KQ1 that - themobilian_2155.jpg
Your dryer has a fuse right there beside the filter housing. When the drum temp exceeds 350f rapidly this fuse melts and kills power to the door switch. themobilian_2156.jpg
If the fuse is fine then chI have a whirlpool dryer mod #LER5620KQ1 that - themobilian_2157.jpgbr />themobilian_2157.jpg
I have a manual and more repair photos HERE
Whirlpool ler5620kq1 wont turn on. Where do i begin?
Hay william , start with the door switch if that doesn't help test the fuses for continuity good luck APPLIANCES R EN
Mar 02, 2013 | Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
No power to Whirlpool Condenser Dryer AWZ7813
check your wall plug it could have went out
Jan 29, 2010 | Dryers
LER5620KQ1 Where are the fuses located.
ther are no fuse's in your whirlpool dryer.nead to know what the dryer is doing or not doing.
Nov 17, 2009 | Whirlpool LER5636P Electric Dryer
Burning Smell from Belt on Whirlpool Dryer
Hi, You need to check and see if the belt has slipped off of one of the pulleys. Was the idler the wheels style or a glide style?
Make sure the grooves in the belt are facing the drum and they are in the grooves of the motor pulley.
Please let me know if this helps and if I can assist you further.
Vic
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
I have a whirpool dryer Mod#LER5620KQ1 the dryer makes a grinding noise when you turn the power on what can this possibly be
Check for metal shavings under the unit pull off the back cover. It seems like this can be one of a couple things. Bad main bearing, your clutch is not fully disengaging or the brake is not disengaging
Feb 18, 2009 | Dryers
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer has trouble drying (LER5620KQ1)
Hi rfairess
it sounds like the high limit thermostat is cutting out and not resetting itself.
Sep 16, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer (electric) model:LER5620KQ1
Do you hear the motor running?? if so your belt broke you will need part # 341241 if you need help changing the belt let me know
Nov 19, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
190 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
