Question about Ovens
I have a FRIGIDAIRE STOVE the broil works an the top of the stove works if you turn on the oven the igniter lghtes but the oven dont come on.
  • Larry Harris Apr 08, 2011
    i have a Frigidaire stove the top works the boiler works but my oven dont.The igniter glowes but the oven do not come on. Iv tryed to find a pilot an seem to be able to locat one model # FGF368GSJ
  • 4,323 Answers
Hi
If the igniter glows then it seems that is fine and also the valve, the only thing left is the burner that should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 08, 2011
    Brigadier General:
  • 4,736 Answers
Below the ovens floor pan, there is another burner (the oven burner) . Despite have electronic ignition, the main oven burner has a pilot light and it may have gone out. The oven's floor pan will lift out, once your remove all the oven racks. Once it's removed, you'll see the burner and the pilot assembly. Note whether or not you see a small pilot flame. If you doesn't you will need to relight it. Either with a long stick match or a butane match. Press the oven knob in while you attempt to do this. Once it lights, release the oven knob and the pilot should remain lit. If it doesn't it may need cleaning. Which can be accomplished using a can of compressed air with a straw nozzle (like you clean your computer with). Simply, blow out the tip of the pilot and any other debris you may see. Try relighting the pilot as directed above and this time after it lights, hold the oven knob in for 30 seconds before releasing it. That should allow the pilot to light and hold. If it does, carefully replace all the parts you removed and wait another 5 minutes before turning the oven ON.
If the above doesn't solve the problem, the thermocouple for the oven burner will need to be replaced.
Hope this helps you troubleshoot and solve the problem.
Posted on Apr 06, 2011
  • Rich Landrum Apr 08, 2011
    Good, Larry, Did that help you locate the pilot on your range?
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
New installation, does not heat
I think your ignition does not work.
Is this a brand new oven ?
Does it have a stove on top ?
does the stove work ?
Dec 28, 2007 | GE Profile JT915 Electric Single Oven
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
Kenmore stove model# 665.92024100 While cooking
Check and see if the broil element has shorted to ground.
Bonus
Apr 13, 2010 | Kenmore Ovens
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
I have a whirlpool gas stove, the bake or broil will not light.
Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Ovens
My oven wont work?
check your breaker to see if it tripped,sometimes the breaker will trip and one or the other wont work.meaning the stove top or oven.also check and see if their are any breaks or burn spots in bake element and your broil element.
Mar 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire stove problem
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Jun 20, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
