Question about Crosley CDE6000 Electric Dryer
Gets hot but wont turn - Crosley CDE6000 Electric Dryer
  • Crosley Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Apr 07, 2011
What could be the problem
Pull the pump out and see if just running 12 volts across it gets it to work. If that happens then it is not the pump at all but more likely fuse board or even the body computer.
Feb 14, 2015 | Cars & Trucks
Hot Starting Problem
hard starting problems when engine hot could be restricted air filter.restricted clogged fuel injectors.engine could either be diesel or gasoline.if engine dont start and starter wont turn over engine. could have bad battery ground cable or battery positive cable could have broken place when cable get hot crack increases cause less current engine wont have enough power to turn over.
Apr 30, 2013 | Peugeot Cars & Trucks
Kurio wont turn on and gets hot
read my other solutions. you have to reset or root the device true the micro SD input. really easy
Dec 27, 2012 | Techno Source Kurio Kids Tablet With...
Estate dryer modle TEDS680EQ1 turns on but wont get hot
Check all the thermostats for continuity.
Dec 01, 2012 | Whirlpool Dryers
My 1998 malibu runs hot when not moving, and now the heater wont work
Does the engines electric cooling fan turn on when it gets hot? Does it cool off if you turn the AC on?
Feb 24, 2012 | 1999 Chevrolet Malibu
AC BLOWER MOTOR GETS HOT THEN TURN OFF.
I HAVE A 1998 CADILLAC DEVILLE,THE AC BLOWER MOTOR GETS HOT AND TURN OFF AND WONT TURN BACK ON UNTIL IT COOL OFF, WHAT IS THIS PROBLEM?
Jul 04, 2009 | 1999 Cadillac DeVille
Dryer wont turn inside but gets hot and turns on
If it's not turning at all, the belt is probably broken. If it turns a little and then stops, the belt is slipping. In either case, the belt needs to be replaced.
May 11, 2009 | Dryers
My ipod nano wont do anything
try reseting it with holding down the menu and center button. Your warrenty will have been voided due to the liquid damage though so if you cant get it working with the reset your gunna need a new one.
Apr 17, 2009 | Apple iPod nano
Crosley CDE6000 Electric Dryer Logo
55 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
