Question about D-Link DP-300U (DHDP300U) Print Server
D-Link DP-300U Print Server Problem:
When I am checking the configuration of print server; From my end it is accidently disable the tcp/ip settings.Now I am checking it on PC admin and web browser it is not detecting.
  • 3 more comments
  • Anonymous Aug 24, 2008
    how to reset the printer server?
  • Anonymous Aug 28, 2008
    how do i reset the printserver
  • mtssys Sep 15, 2008
  • Anonymous Feb 27, 2009
    ha ha ha same question, where is the magic reset button ?
  • Quantiera Apr 15, 2009
    i need to reset this things but how?
  • 24 Answers
So... you've messed up the IP address on your DP-300U and now you can't even access the web browser configuration page? Yes, it's happened to the best of us. Although I'm sure there are more elegant solutions, one fix is to reset the server to its factory settings and then reconfigure it from scratch. Given that there is no reset button on the DP-300U, resetting can be frustrating, especially if it's asking you for a password that you never created in the first place! Here's what you can do...
1) Install the psadmin software which came with the print server. If you lost the software, you should be able to find it on the web somewhere.
2) Start the software. It should automatically locate your print server.
3) Click on "factory reset". If it demands a password, and you don't know it, try "SYSxxxx" (where xxxx is the last four digits of the MAC address written on the underside of your server)
4) Dust off your Quick Install Guide and go through the unintuitive configuration process. If you no longer have your Quick Install Guide you can find it on D-Link's website.
Posted on Dec 31, 2009
  • leonjg Jul 26, 2011
    Ps Admin Software and DLink Software could be found at:
    ftp://ftp.dlink.es/Print%20Server/DP-300U/Software/PS_Admin/
    Best Regards,
How do I start setting up my DP-300U Dlink Printserver from the scratch for the first time into my network?
Posted on Mar 18, 2010
  • Femini Mar 18, 2010
    Expectin a urgent answer please.
    Thanks.
Plz solve my problem my print server is dlink dp-300u defulal gate wate is 192.168.0.10 and iam set the ip is 10.14.2.121
Posted on Mar 10, 2010
Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
I have Dlink DP-300U print server which has ip address of 192.168.2.150 but i want to change into 10.xxx.xx.xxx ip range how can do? i tried by changing the ip address of the pc to Dlink switch range but...
Ideally, you change your PC's NIC to an IP in the range of 192.168.2.150, say 192.168.2.2 with mask 255.255.255.0 then directly connect your NIC to the Print Server and open your browser to 192.168.2.150, from there change the IP address of the Print Server.
Jun 25, 2011 | D-Link DP 300U (DP-300U) Print Server
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
Configuring a Mac Book Pro laptop with a DP 300U Print Server
I connected my HP5MP to the DP-300U LPT1 port.
I configured my port on the DLink Configuration tab, giving it a name "hp5"
...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
On my Mac, I go to System Preferences > Print & Fax
Click the + to add a new printer
Select the IP option
Choose the Protocol: Line Printer Daemon - LPD
Type in the Address: 192.168.0.10
Type in the Queue: hp5
Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
and find the driver for your HP LaserJet 5MP.
Save it. Works like magic. ;-)
If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
May 10, 2008 | D-Link DP 301P (DP-301P) Print Server
My browser can not find server's web
check to see if you have Proxy server in your internet explorer settings ... if you're using proxy server then disable it to gain access to the web interface
Dec 20, 2007 | D-Link DP-300U (DHDP300U) Print Server
Can't connect to DP-300U control panel
Oooh, same with my problem. I have DP-300U, and now that can't use.
How the producer dlink DP-300U, please follow up this problem !!!
Nov 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
DLink DP-300U Print Server
What is the IP of the Print Server and the Printer itself? They have to be on a 'flat network' or the gateways of the the 'adjacent' networks have to be defined as a neighborhood.
Nov 15, 2006 | D-Link DP 300U (DP-300U) Print Server
D-Link DP-300U (DHDP300U) Print Server Logo
4,389 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
