Question about Mtd Craftsman 4Cycle Mini Tiller
Tines aren't turning properly. Stop turning when should be tilling. was working properly yesterday?
  • 15 Answers
SOURCE: I have a craftsman tiller
Look on the shaft and see if there is a shear pin or a keeper. ie: half moon or square. If not, it is time to open the gearbox
Posted on Apr 24, 2009
  • 45 Answers
SOURCE: Tiller will not till in forward motion.
sounds like your drive belt is worn or the handle bar adjustment is too tall and your handle is not adjusted.
Posted on Apr 29, 2009
SOURCE: tines stop under load
Need Owners Manuel for a Ryobi (ZRRY46501) electric Tiller?
Posted on Aug 13, 2009
SOURCE: tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Posted on Jun 30, 2010
SOURCE: tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Posted on Apr 16, 2011
Tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Apr 30, 2012 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
I purchased a Craftsman 205cc dual rear tine tiller (17" width) in 2009. I used it very little to break ground for a small garden (32'x12') after purchase then to till it a couple of times a...
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
Mar 05, 2017 | Craftsman 205 cc 13" Dual Rotating Rear...
Just bought an older Mantis 2 cycle tiller. The tines engage when the tiller is started. Of course that makes it hard to start with the tines on the ground! I don't believe it was doing this when I...
if the idle is too high the tines wont stop due to the tiller tines are run by a "centrifuigual clutch" which means when you increase the throttle speed the tines will start to turn : there are 2 adjustments you can try,1) adjust the idle screw under the carburetor where the throttle adjustment and a triangle piece of metal touch(your throttle cable wire will be attached to this triangle) ,if the triangle and idle adjustment don't touch and there's a gap between these 2 pieces close the gap by adjusting the 10mm adjusting nut,this will correctly set the idle #2) adjust the idle adjustment screw talked about above till the tines dont turn with throttle set at idle or lowest speed setting
Mar 26, 2011 | Mantis 2-Cycle Tiller
Tines turning, mantis 2 cycle tiller
Jun 30, 2010 | Mantis 2-Cycle Tiller
Tines will not turn when engeged. made a grinding
It sounds like a problem with the drive pulley on the engine to me. Maybe the key is striped.
May 27, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
My yard machine tiller pops out of till when i put a load on it. Tines turn when not in ground. Replaced belt all ready Please help. Frustrated
adjust the travel on the rod that engages the tines,it sounds like its not getting locked into till position far enough and the vibration of the unit knocks it back out of till position
Apr 15, 2010 | Garden
Tines stop under load
you have to get someone with a big tractor to "break" the ground up first. A tiller is just that...Not a plow
Jul 26, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Kicks out of till
Best thought is readjust the gear control rod. That or the gears are allready stripped .
May 01, 2009 | Craftsman 8.50 Torque Rating Dual...
Mtd Craftsman 4Cycle Mini Tiller Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
