Question about Digital Mind Corporation HD-500 MP3 Player
Hello: I have a DMC Xclef and the on-disc software
Hello: I have a DMC Xclef and the on-disc software to allow it to encode MP3 files has been lost. Can I get the software somewhere to reload on the unit? Thanks, Dave
My xclef 500 hard drive just died after about 45,000 hrs, 7yrs of use. I was just barely able to retrieve the syst files off the disc and transfered them to another hd. Had a 160gig hd, but had to format it to 100 gigs for the player to use it. I have copies of the file folders that I could post to a site, if it allowed me to. Too bad this site won't let me post files.
Posted on Jan 14, 2012
2 Suggested Answers
Betti_B00p
SOURCE: My Xclef HD-500 will not boot up.
My OH finally solved this himself today! You need to update your firmware - just Google for Xclef HD500 Firmware and you'll find plenty of sites. He went to www.emmeau.com/xclef and downloaded firmware version 1.097 from the firmware section. This is an oldish version but I gather the latest ones can give some bother - and all I was wanting was my Xclef working again. You'll find full instructions there, too, but you'll need to download a couple of files - connect the XClef by the USB port and the power adapter (very importan!!!t)and then copy the two files into the "Firmware" folder of the Xclef. (If you go to My Computer you can see the connected Xclef there as another drive of your computer, and can look at all the folders and files, as you'll no doubt be aware). Do a USB safe removal in the system tray and unplug the USB cable, power on the Xclef - the firmware will update and it switches itself off automatically. Power on the Xclef again, press 'Menu' key for a couple of seconds, go to 'set-up', then 'system', then 'system initial' then 'OK' then switch off the Xclef and everything should be fine next time you use it. HOPE THIS HELPS!
Posted on Oct 18, 2008
Dvd player will not play disks that a lap top will. it says can not read disk.
Page 12 of the manual...
Just the CD discussion. DVD is above it on page 12...
CD [CD] [WMA] [MP3] [JPEG] [VCD]
≥This unit can play CD-R/RW recorded with the above formats. Close the sessions or finalize §2 the disc after recording.
≥ [CD] This unit is compatible with HDCD, but does not support the Peak Extend function (a function which expands the
dynamic range of high-level signals).
HDCD-encoded CDs sound better because they are encoded with 20 bits, as compared with 16 bits for all other CDs.
≥ [WMA] [MP3] [JPEG] This unit also plays HighMAT discs.
≥[WMA] This unit does not support Multiple Bit Rate (MBR: a file that contains the same content encoded at several
different bit rates).
§1 Includes single-sided, dual-layer discs.
§2 A process that allows play on compatible equipment.
≥ It may not be possible to play all the above-mentioned discs in some cases due to the type of disc or condition of the recording.
Discs that cannot be played
DVD-RW version 1.0, DVD-ROM, CD-ROM, CDV, CD-G, SACD,
DivX Video Discs and Photo CD, DVD-RAM that cannot be removed
from their cartridge, 2.6-GB and 5.2-GB DVD-RAM, and "Chaoji
VCD" available on the market including CVD, DVCD and SVCD that
do not conform to IEC62107.
Feb 02, 2011 | Panasonic SC-HT740 System
Tip
Do I use CBR or VBR for my TMPG v4.0 Xpress MPG2 encoding ?
VBR (Constant quality)
Used to make high quality clips no matter the file Compared to VBR (Average bitrate) this mode generates a bigger file but insure the best picture quality control possible.
Encodes using the VBR bitrate control mode, allowing for a smaller final output file size but requiring a longer processing time.
CBR (Constant bitrate)
This is the Usual encode mode for most commercial DVD.
Because the encoding process is streamlined this mode allows a fast encoding but creates relatively big file due to poor optimization. This mode is usable when file size is not a constraint. Encodes using the CBR bitrate control mode, allowing for faster output but without bitrate allocation optimization, resulting in a bigger file size and possible picture quality degradation in scenes with a large amount of motion.
on Jan 19, 2010 | Global Star Software TMPGEnc DVD Author...
What does unknown format mean? Why can't i play music?
what this means is that you are trying to play an audio file on your mp3 player that is not supported by the player and thus it will not play. in order to make the audio file in question play, you will need to convert it into a readable format that is listed by the player it's self. to do this, find out what type of audio file it is (this can be determined be the file extention [.mp3, .mp4, .wav, .m4a, .flac] assuming your computer is set to allow you to see it. though most operating systems will display the file type in the info bar.) then search for "[insert format here] to mp3 converter" and purchase the software required. most of this software is relatively cheep and works on more than one file type.
Dec 23, 2009 | GPX Audio Players & Recorders
Won't recognize an MP3 format CD
Usually a disc with audio files is not encoded with MP3's, but, rather, audio files. You can check this by manually opening the disc (right click on the player when the disc is in it), and looking at the files. If you only see marker (files of a few kilobits) in "MP3" format, then the disc needs to be "ripped" into MP3 format.
The ratio for audio to MP3 is 10 :1--this means a CD of 700 MB size with 10 tracks will become an MP3 collection of 10 tracks approximately 70 MB in size (this is a standard 128kbps audio quality CD) If the encoding is less (64 or 32kbps), the size of the resulting MP3 is smaller.
The hands down best ripping software to convert your audio CD to MP3's is called Goldwave. Although Nero and Winamp have functionality on a limited basis for this task, Goldwave is a far superior software package to not only rip, but also edit your creations. Once you have installed Goldwave, you use the OPEN CD button to read your files---then save them to your hard drive (in what CODEC or quality you want---MP3, Apple AIF, OggVorbis, etc.etc
Mar 27, 2009 | Pioneer DVR-107D DVD±RW Burner
MP3 Player not recognizing Real Player Video Files
That Opal's Easy Rip Software does not recognize Real Video format naturally. You may have to download a free program called Riva FLV Encoder to convert the Real Video files to AVI format. Once they are in AVI format, the Easy Rip software will recognize the file and convert them to your player. If you have lost your installation CD, you can get the Easy Rip software from:
www.rcaopal.com
-Tha Mp3 Doctor
Mar 12, 2009 | RCA OPAL M4001 MP3 Player
How to download songs to the MP3 player
iTunes is an application that allows the user to manage audio and video on a personal computer, acting as a front end for Apple's QuickTime media player. Officially, using iTunes is required in order to manage the audio of an Apple iPod portable audio player, although alternative software does exist. Users can organize their music into playlists within one or more libraries, edit file information, record Compact Discs, copy files to a digital audio player, purchase music and videos through its built-in music store, download free podcasts, back up songs onto a CD or DVD, run a visualizer to display graphical effects in time to the music, and encode music into a number of different audio formats.
You have to download iTunes software and make a playlist then sinc the ipod.
Dec 23, 2008 | 2007 Alfa Romeo Spider
Oct 08, 2008 | Digital Mind Corporation HD-500 MP3 Player
I have a DMC Xclef HD 500 I accidently formatted now Now anytime I turn it on it says not formatted. I believe that I need the original programing
It would depend on how it was formatted. Did you remove it from the player and format it on a computer? The Xclef requires a FAT32 format / partition. I've upgraded the drive in mine on two occasions & found the easiest way to format the drive (there's no easy way though a windows OS) is to use this utility . . . "fat32format" . . . http://www.crapcontrol.com/e107_files/downloads/fat32format.zip
Good Luck
Oct 03, 2008 | Computers & Internet
Grrrrrrrrrr
I hope you tried the slide on the right side that say's hold
Oct 01, 2008 | Digital Mind Corporation HD-500 MP3 Player
Cant add music
Hello
I had the same problem.
I suggest you visit this link and sony's esupport site where you can download an MP3 file manager.
I hope this works for you
Aug 06, 2008 | Sony Walkman Bean NW-E305 MP3 Player
Digital Mind Corporation HD-500 MP3 Player Logo
213 people viewed this question
Top Digital Mind Corporation Audio Players & Recorders Experts
Computer Links
Jonathan Poston
Are you a Digital Mind Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
