Question about Frigidaire Washing Machines
Need a belt diagram for figidaire dryer model number fex831cso
    Brigadier General:
  • 6,277 Answers
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer technical manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct. You may find, however, that it will supply only to service engineers but good luck anyway.
John C.
Posted on Apr 06, 2011
Tip
My Frigidaire Dryer is not heating anymore. Repair and testing for model...
Hi.
The example is referring to Frigidaire electric dryer model FEX831CSO. If you have a different model see here how to locate parts and diagrams: Where do I find parts and diagrams?
First part to test is the thermal fuse located at the back of the appliance. This is tested reading Ohms on fuse contacts. follow procedure explained further below to test the fuse.
If the fuse is not the culprit, it will be neccessary to access heater assembly and thermostats.
You access the heater parts by opening the top panel, part 3 on diagram below.
The heater assembly is part of the housing, and it is part 15 on diagram.
Replacing the heater requires further disassembly, first ensure that the problem is not a defective thermostat or thermal limiter. The thermostats fails far more commonly than the heater.
To test heater and thermostat use a multimeter set at Rx1. disconnect the thermostat contacts and read impedance at room temperature.
If the thermostat is good it will read zero or very low impedance.
An alternative way to test a thermostat is by jumping its contacts.
The element is also tested reading impedance. If the element has no continuity (infinite Ohms), then it must be replaced, otherwise it is good.
Test both the thermostat and the Thermal limiter, they are tested in the same way. Both this parts are accessible after removing the top panel, and can be replaced without further disassembling.
Here the parts:
Thermostat:PS446428 part 33 in diag.
Thermal limiter:PS419402 , part 36 in diag.
Test and repair must be done by a trained person. Call the phone number listed on the user manual if you need to contact a qualified technician.
Regards.
on Apr 09, 2010 | Frigidaire FEX831CS Top Load Stacked...
Threading the dryer belt on my stackable frigidaire model. i need a diagram please.pulleys,tensioner and drum it is not getting tight. just need a pic.
A model number would have helped me help you a lot quicker. It took a lot of time just to try and guess here.
Yours will be one of these 2 diagrams:
westing.gif for 1995 and newer models ^--NOTE Belt ribs away from the drum on this one: frank.gif 1985-1995 models ^-Note: Belt ribs face drum on this one Thanks for choosing FixYa, Kelly
Aug 17, 2011 | Dryers
Need to get to the pump, clogged hose. Need a diagram of how the take the front panel off of a Model FEX831CSO frigidaire washer and dryer stackable
Your model number ends in a zero, not the letter O so maybe this was giving you trouble finding the diagram. In any case here is the diagram for your model washer.
Aug 03, 2011 | Washing Machines
We need to know where the tension pulley goes and we need a diagram to show us how it goes in
You can view an extensive list of dryer belt diagrams at the following website:
http://www.repairclinic.com/Dryer-Belt-Diagrams?red=Dryer-Repair-Help
The diagrams are listed by manufacturer and model. If you still need assistance in determing which diagram to use, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: If the link does not work for you, go to repairclinic.com and click on the "Get Repair Help" link at the top of the page. Select "Dryer", followed by the "Click here for belt installation diagram" link.
Nov 23, 2010 | Dryers
Need diagram for belt and idler on dryer
That model number is not correct. Look here for where it's located. http://www.appliancepartspros.com/modelnumber_locator.aspx
Aug 08, 2009 | Kenmore Dryers
My frigidair FEX831CSO stacked washer/dryer has quit drying. Was wondering where the heating element is
Try to get in the back of the dryer section? If you can, i believe you can get to it from the back im not to sure, its been a while since i work on this model...to help you out better go to this websit www.partselect.com and then type in your model number. click on your model number and it should pull up diagrams. click on the dryer section and it shows where each part is located...hope this helps...
Jul 30, 2009 | Dryers
I cant find my dryer model number online.
Go to appliancepartspros.com and type in your model number. Use the suggested model number they provide, which is the XMW0 suffix you have listed. The part numbers will be the same for these models. If you look under the "Cabinet" diagram at item number 56, it states in the part description that this belt replaces the 5 rib (wider) belt that you have and fits all Whirlpool models. The part number is AP2946843.
For a diagram on how to replace the belt, go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, is a link for "Dryer Belt Diagrams" under the "Special Features" section. Scroll down to Whirlpool and use diagram H. I hope this helps you. Let me know if you require additional assistance.
Jan 03, 2009 | Dryers
I am trying to replace the belt but the drum is still attached to the back (I have taken every visible screw out). Should I try from the front? Is there a way of getting the drum unsecured from the...
Hello mcbeanga,
Please find a link to an exploded view f your dryer http://www.pcappliancerepair.com/model-display.php
In many cases ( and I am not all that familiar with your figidaire model) belt replacement can be handled by removing the front and top panel. The exploded view may help a bit. Once you have the front removed, pay particular attention or take a digital picture if you have a camera handy) of the path that the belt takes around the pulley system and tensioner. Hope this helps you,,,
Regards,
Rick
Nov 23, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Washing Machines Logo
160 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
