Question about HP Computers & Internet
I LOOSE MY SETTING WHEN I SHUT IT OFF - HP Computers & Internet
  • afa5rs Apr 06, 2011
    I am not loosing my date & time just thewirelee internert & to wire less printer.
    Raymond
  • HP Master
  • 6,771 Answers
If you are losing your settings, date, and time. The cause is a bad c-mos battery located on the motherboard, the battery is silver in color round, and about the size of a quarter. It will need to be changed, clips into a holder.
Posted on Apr 06, 2011
  • John Cunningham Apr 07, 2011
    This is a device issue, and there can be any number of reasons for this, check your manual to see if it can shed some light on the matter. If the printer is an HP for example go on line and check to see if there are known issues with your model, and check for an update driver, out of date drivers will cause all kinds of problems.
Tv screen goes blank after a few minuites on
Check you setting a make sure some screen saver is not turned on. It's more common for Plasma screens then for LED/
LCD or LCD/Fluorescent sets. Also, if it senses no video input some sets will just turn off the screen and then eventually also turn off. Of course, it could also be defective. It would not hurt to check for a loose plug as well. If it is not firmly in it could take a minor movement to make the connection not complete and the TV could shut off. I sometimes set my TV to the tuner after watch videos just so it will not shut itself off if I'm gone for too many minutes.
Aug 13, 2014 | Televison & Video
My door ajar light and beep keep randomly going off while driving with all doors shut completely.
either a door sensor is bad or a door latch is loose. you can take it to a ford dealership and they can look up which door is setting it off. Just double check the rear truck door and also the window in the rear door if thats on a latch.
May 03, 2011 | 2002 Ford Explorer
Does not matter what the setting is on,the microwave will only run for 2 min. and then shut off. It is only 5 yrs old.
Please check all the poer connections on the power side, the magnetron section. specially the capacitor. Also if there is fault on the control processor board.
This can trip off the power and reset. possible loose connection or even if the outlet power - if it is lower when the microwave starts.
Feb 18, 2011 | Magic Chef MCD1311ST Microwave Oven
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
Power save mode
Enter in the User programs and select the auto power shut OFF setting.Use this setting to enable or disable auto power shut OFF,press 0 to OFF or 1 to ON.The program name is auto power shut off setting and the program number is 5.
Nov 19, 2009 | Sharp AR-M205 Copier
Denon AVR588 receiver auto shuts off
You may reset the unit to factory setting. Hold buttons "Speaker" and "SpeakerB"and turn on power switch. Release buttons after 5 seconds. You will loose all your setting and need to do configuration again.
Jul 07, 2009 | Denon AVR588 Receiver
Dryer overheats.
Remove the vent pipe from the back and run the machine on a no-heat setting. You should be getting good strong airflow. If not, the blower wheel is probably loose on its shaft and needs to be replaced. Without the necessary airflow to distribute the heat, the machine can overheat and shut down.
Apr 06, 2009 | Whirlpool Dryers
Set timming
You will need a timing light for Hi energy ignition as well as standard socket set or wrenches. 1. get the engine up to operating temp. 2 shut off engine connect the timing light to the number one[1] spark plug wire at the spark plug end connect battery connectors. 3 start engine and note location of pointer on the mark tab on the timing cover. 4 shut off engine loosen the hold down clamp on the distributor turn the bolt no more than one full turn[snug is better than loose here] then note the position of the dist. cap. Move the dist. to make sure it moves freely replace back to the starting position and remove and plug the vaccum line to the dist. 5 start engine and set timing to the desired spec. 6 shut off engine tighten dist. clamp bolt 7 start engine check timing one more time to see if still there at desired setting. 8 shut off engine dis-connect all tools and light
Apr 02, 2009 | 1994 GMC Sierra
Loses channels when shut off. must auto program
Your may be in shop mode, I'm not sure if Vizio's have a service menu. Go to setup and go through the install process again, watch for a demo or shop mode setting. If there isn't a setting then you need a new mainboard
Mar 22, 2009 | Vizio VW32L 32 in. LCD HDTV
Computers & Internet Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
