Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I had to remove a momentary power switch from my Motorguide foot control due to the rubber boot being worn and no contact being made. Forgot to document where the three wires were connected to the two screws (one screw in center of switch, one off center). I thought I remembered the black being on center and the white and colored wires being together on the other, but I'm not sure. please advise. Thank you
SOURCE: have a motorguide foot control ''750 Classic'' 12/24 volt troller
I have one that says manufactured in 1999.
Posted on Dec 11, 2008
  • 5 Answers
SOURCE: can you change a motorguide 65lb thrust foot
Go to TROLLINGMOTORPARTS.COM AND YOU CAN A WIRING DIAGRAM.
Posted on Apr 30, 2010
  • 24 Answers
SOURCE: I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Posted on Jun 29, 2010
SOURCE: My variable speed motorguide only
Would you mind letting me know how you made out? I have the same problem.
Thanks, Mike
carmic@wightman.ca
Posted on Aug 18, 2010
  • 509 Answers
SOURCE: i bought a used trolling motor (motorguide brute
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Posted on Dec 23, 2010
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
I nned a motorguide 46 lb. thrust electric foot controlled trolling motor manual
Go to http://www.boats.net. Let me ask you a question, is it 5 speed? And if so have you lost some or all speeds but 5?. I so, them you need to take the lower unit apart and you will find solder laying in the bottom. You will see that the speed control coil wires at one if the terminals on the brush board has no solder. Clean it up along with the wires so that you see copper and re-solder. This is due to poor quality control on soldering at the manufacturer. When you re-assemble tighten the bolt 45-50 in-lbs only. No more.
Oct 02, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
My trolling motor stopped working suddenly. It is a 96 motorguide 56. It is completely charged. What else do I check. I check 5 fuses by the battery as well.
First you need to check to see if power is getting to the motor. If power is not getting to the motor, then check the battery. If you are getting power to the motor, then troubleshoot starting with checking to see if power is getting to the foot pedal. From there check the switches, and make sure they all have power. If they do, then most likely it is the brushes which could be worn on the powerhead itself.
Jun 02, 2011 | MotorGuide FW40 FB 42" 12V FLXMT Trolling...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a motor guide 4300 pro series trolling motor. recently I have developed a problem with the control switch turning the motor off and on.I can turn it off and on by the side 12 and 24 volt toggle even...
I'm not sure my earlier post went through..Again, Mine is doing the same thing. I noticed a piece of rubber on the floor next to the foot control. I think this piece of rubber was on top of the switch and allowed it to make better contact with the gray lever. I'm going to tear into mine this week. I'll post my results here.
David
Oct 18, 2009 | MotorGuide Electrical Supplies
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
