Question about Dryers
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly with err code 68 please help me if you can hopefully its an easy fix i have 7 children canot afford another or a repairman or to be without it right now? Thanks alot Mrs. Turner
    President:
  • 3,074 Answers
That's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
http://forum.appliancepartspros.com/dryer-repair/143380-frigidare-affinity-dryer-e68-error-code.html
Posted on Apr 06, 2011
  • 2 more comments
  • kgspgh008 Apr 06, 2011
    Thanks alot timydee that is alot of children and i am in panic mode?LOL But if u dont mind can u please explain wich site will take me to the funtion test? When i click on the link it takes me to different sites and im not sure wich one to go to? Thanks a bunch!!
  • Tim Whalen Apr 06, 2011
    here it is, sanity I hope, Good Luck Tim
    http://manuals.frigidaire.com/prodinfo_p...
  • kgspgh008 Apr 07, 2011
    Thanks alot Tim im gona try it? I really appreciate it!!!
  • Tim Whalen Apr 07, 2011
    Your welcome Mrs. T
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My frigidaire GLTF2940ES0 displays LOC when i press start
Hello & Welcome to FixYa
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
Loc coming up on frigidaire washer front load
The controls have been locked unintentionally and this is a safety feature to avoid having someone accidentally stop the washer or modify the cycle. It can be unlocked by pressing and holding the OPTIONS and SELECT buttons for 10 seconds or until the "LOC" is no longer displayed. Lock the controls with the same buttons and in the same way until "LOC" is displayed alternately with the estimated cycle time.
Jun 19, 2011 | Frigidaire ATF6000ES Front Load Washer
Cycle starts but shuts off. timer keeps running. when we press option select we get LOC. when we hold start/cancel button we get 5 beeps and ESE
Hello
Kevin
Nov 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer won't run. It beeps 3 times and flashes "err" and "LOC".
HI. The term"LOC" will be an indication of the "Child Locking" feature that has been activated either by mistake or intentionally. This is a safety feature to prevent unwanted starts when children are present.
To unlock the controls,press "Options and Select" at the same time and hold for 10 seconds until ”LOC” is no longer displayed.
  • NOTE_ If the release procedure doesn't unlock the unit and the letters LOC continue to appear, this will be a strong indication of a severe fault within the main control board. try to power cycle the unit if this is the case. if the power cycling doesn't produce good results, replace the main control board assembly.
Aug 14, 2010 | Frigidaire ATF6000ES Front Load Washer
The LOC flahes on my display, it allows me to pick a cycle but i can not start it. Please help, i tried to press options and select at the same time for the LOC to stop flashing...is there anything else...
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Jun 19, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My front load washer will not start It keeps saying loc
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.Or press "end of cycle" for over 3 seconds.
May 14, 2010 | Frigidaire ATF6000ES Front Load Washer
My friidaire washer will not start. The door lock light will not come on. The door closes properly. The error LOC comes on. Not sure what else to do. Doesn't seem to be any problem closing the door. Help...
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
LOC Blinking
Control Lock
Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Dryers Logo
414 people viewed this question
Top Dryers Experts
