Question about Whirlpool AWM029 Front Load Washer
The washing machine is indicating to Clean Pump. How do i clean the pump? How also do i clean the filter?
    Brigadier General:
  • 6,277 Answers
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Apr 06, 2011
SOURCE: Whirlpool clean pump problem
where is the pump?
Posted on Oct 19, 2008
futureloginn
  • 734 Answers
SOURCE: miele washing machine wont drain
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
  • 1891 Answers
SOURCE: How do I clean my whirlpool washing machine pump?
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help, it worked like a charm."
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
SOURCE: My Whirlpool washing machine WFS1273AW,
The same thing happened to me and it was because there were socks stuck where the drain pipe attaches to the machine. If you tip your machine on its side and pull the black pipe off from the bottom of the drum you can remove anything which is stuck. Then it just clips back on again with a metal clip.
Posted on Sep 04, 2010
I have wm1814cw lg front loader washing machine with oe light on and not draining we have clean filter unclogged drain hose and reset by unplugging and holding down power putton and start button als
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Sep 16, 2014 | LG Washing Machines
How do I clean the washer pump filter in my GE-WCVH6600HGG?
please go through this http://www.youtube.com/watch?v=x7rJkWE0nN0
Instructions:
  • Examine if there's a problem with the filter. If the machine isn't draining, spinning or agitating, the washer pump filter may be clogged, and you should clean the pump filter. Other giveaways that the filter may need cleaning include the washer performing an incomplete cycle, the timer not advancing or the washer just not running
  • Open the pump access door with a coin. Remove the pump filter by turning it counterclockwise and pulling it out.
  • Clean the filter with your fingernails, removing all loose debris. Wash the filter under running water until it is clean.
  • Replace the filter. Insert it back into its housing, turn it clockwise and close the door.
  • i hope this helps you ,thank you
    Feb 10, 2011 | GE Washing Machines
    The clean water pump is flashing on my whirlpool awo/d4505 washing machine where is the pump and how do i clean it ?
    There should be a access panel on the front of the machine at floor level.
    This will have a filter which you need to clean. This filter is on the input to the pump.
    Feb 03, 2010 | Whirlpool Washing Machines
    My washing machine showing an OE error before end of cycle
    OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
    Jan 18, 2010 | LG WM-2277HW Front Load Washer
    Clean Pump
    The pump must be cleaned...u can call for the service technician.
    Oct 13, 2009 | Washing Machines
    Clean pump indication light on .how do i clean pump
    dear sir/mam
    clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
    Sep 11, 2009 | Washing Machines
    My washer gets so far then says fp
    fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
    Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
    Flashing f 2
    The F2 code indicates the drain pump has either failed or become clogged.
    To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
    If you need further assistance, let me know
    Regards,
    reg501
    Jul 14, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Washing machine
    Make sure you are using HE soap, regular soap will produce sudsing issues in front loading machines.
    F21 indicates a clogged pump or a long drain. Since you are also getting a SD error indicating a sudsing issue, the water level switch (pressure switch) may have failed. If you would like to make sure the pump is not clogged, you can clean/inspect the pump filter;
    • Remove the bottom access panel (three screws along the bottom).
    • There you will find access to the pump clean-out. (Large,white screw cap)
    • BE PREPARED TO CATCH SOME WATER.
    • CAREFULLY AND SLOWLY unscrew the pump clean-out, catching and discarding the water.
    • When the water flow finally stops, completely remove the clean-out filter.
    • Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris
    Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    This is from the Whirlpool user manual for the AWO\R 4205 - it tried it and it worked well, found a hair grip and some stones in mine!
    We recommend that you check and clean the filter
    regularly, at least two or three times a year.
    Especially:
    If the appliance is not draining properly or if it fails to
    perform spin cycles.
    . If the pump is blocked by a foreign body (e.g. buttons,
    coins or safety pins).
    IMPORTANT: make sure the water has cooled
    before draining the appliance.
    1.
    Stop the appliance and unplug it.
    2. Remove the plinth by using the separator of the
    detergent dispenser (fig. .A.).
    3. Place a container beneath it.
    4. Open the filter but do not remove it completely.
    Slowly turn the filter counterclockwise (fig. .B.) until
    the water begins to drain out.
    5. Wait until all the water has drained.
    6. Now unscrew the filter completely and remove it.
    7. Clean the filter and the filter chamber.
    8. Check that the pump rotor moves freely.
    9. Re-insert the filter and screw it in clockwise as far as it
    will go.
    10. Pour about 1 litre of water into the detergent drawer
    to reactivate the .Eco system.. Check that the filter is
    inserted properly and securely.
    11. Reinstall the plinth.
    12. Plug in the appliance again.
    13. Select a programme and start it.
    Dec 16, 2007 | Washing Machines
    Whirlpool AWM029 Front Load Washer Logo
    128 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
