Question about Philips 50PFP5332D 50 in. Plasma Television
I have fixed two capacitator and I still keep on experiencing the red blinking light I was told it could be the main power supply box how can I fix this
  • Philips Master
  • 3,459 Answers
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 18, 2011
TV won't turn on. Red standby light blinks
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
Nov 06, 2013 | Samsung BN94-05038F Main Board for...
Watched a 3hr movie.Started the second movie and heard a loud pop and then the picture was gone but there was sound.Took the back and side panels off and found a bad fuse.Strange thing is tho when you plug...
There is a good chance that one or more jugs (CRT)s have leaked coolant down onto the Main bd and Power supply causing severe shorting. At this point ALL of the CRTs must be replaced and the Main bd and or the power supply as well. This is not a inexpensive fix and after the parts are replaced you will need to do a Full Convergence alignment by a very experienced tech which will not be cheap. You might as well purchase a new TV.
Apr 12, 2010 | Samsung PCL541R 54" Rear Projection...
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
LC-23Y25 Problem with turning on power?
so i had the same problem. red light came on, but no blue light or anything on the screen. it turns out that there were some capaciters blown on the circuit power board. unless you have a good understanding of circuit boards, its not a quick fix. but for someone who knows their electronics, its not too hard, and its not expensive to fix, unless you bring it into a store. but the supplies needed arent expensive. good luck
Nov 09, 2008 | Prima C2012 TV
Philips 42PF9630A 42 in. Plasma 42 in. Plasma
Ok 7 red blinking led, remove the back cover of the TV. Looking at the power supply in the upper left of power supply. If everything is working fine you will see a solid green led if there is an error, you will see this light blinking also. Right below this led on the power board you will see a list of numbers 1-13 this will give u the problems that this led flashing problems are. More and likely u will have a problem with VSET or VSCAN. Which is connected to the Y-Main and Y-buffers,( the board that is too the left of the power supply if u look on the small print on this board you will see that it reads. 42HDV4 Ymain and the 2 small boards connected to it are Y buffers. To be sure that this board is bad if the TV keeps going into error protection. unplug the power supply and wait for the led to stop flashing. Disconnect the cable that plugs into Y-Main from the Power Supply. It should stay running. If u remove this board and look underneath u should be able to see where this board is getting hot. Easiest fix is to order a replacement. Y-main assembly.
May 05, 2008 | Televison & Video
Power light blinks red - tv will not come on
to let you all know that Im having the same problem with my tv.. amber then red red red red... and popping sounds from speakers... Its because they use cheap parts there are 19 capacitors in the power supply (DONT RECOMMEND FOR NON EXPERIENCED PEOPLE) the 2 main filter capacitors are 100uf450v the ones in mine are just fine then there are 3x 1000uf16v, 2x 470uf16v, 3x 470uf25v, 2x 1000uf25v, 6x 1000uf35v, and 1x 470uf35v... Im in the process of replacing those capacitors. about half of them are leaking and 1 is blown... very dangerous for anyone messing around back there.. just thought i would let everyone know that its a 20 dollar repair if you know what you are doing i got my caps at marvac.com
any other questions email pfctmitsubishi@yahoo.com
Dec 04, 2007 | Akai LCT2715 27 in. LCD Television
Power light blinks
I would start with C869 a 2.2 Uf at 200 Vdc in the power supply. I have replaced a fair share of those in these sets. Of course the first thing to check would be the pico fuse in the power supply regulation circuits F860 a 4 Amp Pico Fuse and if it is blown, you will have to replace Q801 the Regulator IC Str-Z4214 Part # 23906369. If you're not that good at soldering and measuring capacitance and resistance, this would be a job for a more experienced tech.
Jan 24, 2007 | Toshiba CZ36V51 36" TV
Philips 50PFP5332D 50 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
