We have a Toshiba 42HM66 DLP. It is at least 3 years old and the lamp had never been changed. Lately the picture has gotten darker and once the unit is on for awhile the picture starts flickering and colors are not right. We assumed it was the lamp. Changed the lamp and still the same problem. Called Toshiba, they could not help but said picture flickering is not a symptom of needing a new lamp. They suggested we call a tech and they gave us a reference. The tech came out and agreed the picture was bad even though a brand new bulb was just installed however it did not start flickering while he was there. He suggested that when it does to call him. He has never seen a problem like this in this model before and his only thought was it was some part that would cost a few hundred dollars. Anyone else have any idea? The owner of this TV is terminally ill and I would hate for her to have to buy a new TV at this point.
  • 1 more comment
  • Lisa Fratangelo
    Lisa Fratangelo Apr 06, 2011
    OK. Please bare in mind I do not know what you mean by Inverter or capacitor. How to I confirm it is not one of these things? We also have a Roku box connected to the TV and when that was on the screen still flickers. However, when I have the menu up, the menu itself is not flickering but the background is.
  • Lisa Fratangelo
    Great I will check and see. Are these expensive parts to replace?
  • Lisa Fratangelo
    Lisa Fratangelo Apr 22, 2011
    OK. The repair man said that these TV's do not have an inverter because it is a DLP. But he still hasn't figured out the problem. Maybe I orignally posted this in the wrong area of this website. However, the flickering seems to have stopped but the picture quality is terrible. This is with the new bulb installed. What besides a bulb would make the picture so bad? You can watch the TV but there is no HD quality that I can tell. The picture is either too dark or too light. Not crisp.
    President:
  • 2,187 Answers
Check if the flickering happens when you have the menu up on the screen. If the menu does not flicker it may be the source of the signal or the connections to it or probable the board where the connections are terminating at. It may also be a problem at the inverter. It may be due to a capacitor that is leaking or swollen and is starting to go bad.
Posted on Apr 06, 2011
  • 1 more comment
  • Nicolo Carlo Parazo Apr 06, 2011
    I see. The inverter is one of the boards on the tv but replacing or taking this off may need a specialist as for the capacitor it looks like cylinders and may have different colors with two legs attached to the circuit board. If they are leaking or swollen they need to be taken out. The technician may not have inspected them.
    the inverter may be pricey but the capacitors, they are the cheap ones the power supply circuit may also be the culprit. It is the first circuit after the power cable. Check for the capacitors as well. The power supply circuit may be a little cheaper than the inverter. Check first my first suggestion if it happens on the menu... thanks
  • Nicolo Carlo Parazo Apr 23, 2011
    did you notice the same problem in all inputs, like DVD players, using the round RCA connectors or TV connection? For the dark or light picture how does adjusting the contrast help? Did you notice the fan turn on or off? I am thinking that its could be a convergence IC issue (one of the flat things on the board with many legs on it) or still a power supply issue if the fan keeps on turning or there was a voltage drop or surge if the repairman measured them.
Picture is getting darker
Many of these DLP sets the picture gets darker right before the lamp fails.
Average life of the lamp is 2,000 hours----about 1 to 2 years of normal use.
If the lamp has not been replaced for a long time it is first suspect in this case.
Let me know if you have questions.
SD TECH
Jan 16, 2012 | Akai PT50DL24 50" DLP TV
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen here is a link with the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=BP96-00608A
Sep 03, 2010 | Samsung DLP HL-P5663W 56" TV
Toshiba M#42HM66 First lamp blew after approx 3 years Bought new lamp and it blew after 3 days. Could I have another problem other than the lamp
Yes usually for a lamp to fail there is a drive problem, one must always fix the causative problem, behind the failure, or as you have seen it will simply reappear. The most common problem is "Dirty Power" to the lamp. But I think it is a problem for the serviceman/center.
Jan 26, 2010 | Toshiba 42HM66 42" Projection HDTV
Picture getting dimmer (?)
Hi, yes it`s time to replace the lamp, and remember to turn maxxed out brightness to normal once you replace the lamp :) good luck, video-tek
Jun 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
14 MONTH OLD TOSHIBA TURNS OFF BY ITSELF
I repair a lot of these and a average tv lasts like 3 years . It is not like the old days. I suspect the lamp or fans or therm protector.
I would call a local tv shop see what they charge for estimate it might be worth his estimate to find out what it is.
Thanks doctor video
May 27, 2008 | Toshiba 52HM95 52" HDTV Projection...
42hm66 toshiba picture quality
I would change the bulb out, if it's not that at least you have a spare when it does go.
do you know how many hours are on your bulb?
good luck
please mark the post with a fixya
Mar 17, 2008 | Toshiba 42HM66 42" Projection HDTV
Toshiba 42 in 720 DLP TV MODEL HM66
You need to replace the lamp in this set. The "pop" you heard was the lamp popping.
Josh
Feb 24, 2008 | Toshiba 42HM66 42" Projection HDTV
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
