Question about Maytag MDE4806 Electric Dryer
Turn dryer on and it runs for about 30 seconds and then shuts down.
  • jaycom7 Apr 06, 2011
    1. If I attempt to start the dryer immediately after it quits it starts 2. When I open the door and hold the door switch, and start the dryer it still cuts off in about 30 seconds.
  • jaycom7 Apr 07, 2011
    Thank you for the information to correct the problem with my Maytag,but after checking your wiring diagram and looking at the wiring on the dryer, I decided to follow your advice and call in a pro because I have no electrical experience.
    Thanks Again
  • Maytag Master
  • 2,605 Answers
Welcome to FixYa.
I should be able to assist you, but first let me ask a couple of question's in relation to your post. When you said "runs for about 30 seconds and then shuts down".
1) If you attempt to start immediately after it quits, will it start?
2) If you open the door and hold the door switch closed (pushed in) and start the dryer, does it still cut out after 30 seconds ?
It's relevant to the motor and door switch. I want to find out if it is cutting out on the thermal overload or otherwise. Your reply will help determine that so I'll watch for your post.
Regards,
Macmarkus :)
Posted on Apr 06, 2011
  • Mark MacDonald
    Mark MacDonald Apr 06, 2011
    Hello again,
    Thank you for replying and providing that info. If you have electrical experience or inclined, you can unplug the dryer, then unhook the belt from the motor, remove the motor wire harness/connections and hook 120vac to numbers 4 and 5 on the motor switch...and old small appliance or lamp power cord with connectors on it works well.
    If the motor starts and continues to operate without fail, it is good.
    Beyond that and you have a multi-meter you will need to now verify the motor drive relay is good. This is on the control board in the control panel/console.
    **These following test's will require the unit to be plugged in so please take caution in servicing the unit. If you do not feel confident in trying this please call in a pro.**
    Since the motor starts initially we know there is voltage on the black wire ( contact PS7 ) at the motor drive relay, but we want to find out if there is power on the gray wire ( contact PS9 ) after 30 seconds when it stops, see illustration below.
    Try this and get back to me. I should mention if the circuit opens after 30 seconds (no voltage on PS9) that would indicate a faulty relay thus needing a new control. Keep me posted.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 07, 2011
    Hello Jay,
    Well let me know how it goes and what is found out. Glad I could help in some manner. Good luck.
    Of course if I can help in any way going forward I certainly will in whatever manner I can.
    Regards,
    Macmarkus :)
3 Suggested Answers
SOURCE: kenmore dryer
that happens to mine when i overload it and the clothes push against the door and open it imperceptibly -- but,evidently, just enough to shut it off.
Posted on Dec 30, 2007
  • 50 Answers
SOURCE: Dryer flame shuts off after about 30 seconds
this sounds like a clogged vent more than a thermostat. go outside with the dryer running and see if hot air is blowing out the vent. if not check outside vent for birds nest etc, inside make sure the vent is straight any dips in vent could cause water to build up clogging the vent. try this first if it doesn't work write back
Posted on Jan 23, 2009
Dv218aew Samsung dryer shuts off itselft after 30 seconds
Bad venting causing overheat? bad thermostats hi limit and cycling? thermal cutt off. bad moister sensor in the drum? giving wrong reading and cuting it off?
Sep 04, 2014 | Samsung DV218AEW Electric Dryer
Maytag Legacy gas dryer shuts down
too complicated the inner machinery is not working nome its bettter to go for a newer one
Dec 16, 2007 | Dryers
We bought a Samsung DV419AV dryer less than a year a go. tonight my wife went down to dry a load of work close for tomorrow and set the drying cycle and pushed the start button. you can hear a hum but the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Dryers
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
Dryer runs but element cyles on and off every 30 seconds
you probably need a thermostat kit, either that, or the venting is plugged causing the safety thermostat to shut the heat down so there is no possibility of a fire.
Oct 04, 2009 | Roper REX4634KQ Electric Dryer
Maytag mdet446ayw runs a few seconds and shuts off
maytag dryer mdet446ayw runs for around 30 seconds then shuts off
Apr 15, 2009 | Dryers
Jan 23, 2009 | Maytag Dryers
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Kenmore dryer
Nov 30, 2007 | Dryers
Maytag MDE4806 Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
