Question about Lexmark X7350 All-In-One Printer
Hi I just change my ink two times in a row and it still wont print what do i do ?
  • Official Brand Answer
  • 3,344 Answers
Will the printer print if you make a copy using the Copy button on the operator panel? Maybe the cartridges needs to be cleaned. Press Copy Mode. Press Hi I just change my - pattlnk_522006_1348-menu.gif -> Press or pattlnk_522006_1348-down%20arrow.gifrepeatedly until pattlnk_522006_1349-side%20pointer.gifappears next to Maintenance.Hi I just change my - pattlnk_522006_1348-select.gifa.net/uploads/images/pattlnk_522006_1348-select.gif" alt="pattlnk_522006_1348-select.gif" class="h_mi" /> Hi I just change my - pattlnk_522006_1348-up%20arrow.gif"http://i.fixya.net/uploads/images/pattlnk_522006_1348-up%20arrow.gif" alt="pattlnk_52Hi I just change my - pattlnk_522006_1348-down%20arrow.gifi" /> or pattlHi I just change my - pattlnk_522006_1349-side%20pointer.gif=repeatedly until pattlnk_522006_1349-side%20Hi I just change my - pattlnk_522006_1348-select.gifpears next to <b>Clean Cartridges</b>.  -> </span><span>Press <img src= A page prints, forcing ink through the print cartridge nozzles to clean them. -> Print the document again to verify that the print quality has improved..
Posted on May 03, 2011
Printer still keeps saying check ink
Did that start with new ink or with part-used cartridges?
Either way will the printer let you clean its heads and if it will, what happens if you clean them at least four times in a row without doing anything else in between, please? (that includes no test prints, no shutting down and restarting - nothing but cleaning at least four times in a row)
Otherwise are you using the maker's own ink and either way, how long ago did it last print successfully?
Aug 24, 2016 | PRINTER Office Equipment & Supplies
Prints too light
What happens if you try cleaning the heads not the standard once, but at least four times in a row without doing anything else in between, please? Don't try a test, don't switch off; just run the cleaning routine at least four times in straight row. (Sorry that might use a lot of ink)
Some, particularly smaller printers don't really like being left more than two or three weeks without printing and it could help to print even just a small test image every fortnight or so. (Again, sorry that uses ink)
Feb 04, 2014 | HP Officejet 6310 All-In-One InkJet...
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
I have just replaced my ink cartridges, but now it wont print anything even though it makes the right noises. it whirs and takes the time it would to print something, but the page appears blank.
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink. The printing device consists of a print head and cartridges with ink. When you change the cartridges that does not mean you change the print head, like in some other models. Now you can choose the "head cleaning" option from the printer settings a couple of time. If this does not help you have two options - to get the device to service center or buy a new one. The second option is the cheaper one I suppose. And remember for inkjet printers you must print at least 1 page per week to keep head from clogging with ink. Hope this helps Alex
Sep 11, 2011 | Epson STYLUS CX5900 Printer
My mp mP830 prints some lines (or partial lines) Consistantly misses the same rows each page
Sounds like the ink is running out at the same time each printing. Check the ink supply. The printer may not be letting you know the correct amount remaining. It could also be the ink jets themselves getting clogged and not distributing the ink enough to compensate for the amount of printing ink, on the page, in time to print all of it in succession. Do a test of no printing except where it seems to be missing and just print that area (print: selection).
Sep 16, 2010 | Office Equipment & Supplies
Printer wont print ink keeps blinking on system
Hi
You not say what make of printer you got so not can gave you much help, because there is a reset code for different printers, the flashing lights you may be getting it because your, waste ink pads need changing and after this you need the reset codes for it but some times just the reset code will do the trick for it to print again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Office Equipment & Supplies
My printer wont print, plus the black ink seems to not work
maybe your ink cartridge is damaged. Try to change your ink cartridge (black). Or your printer has reach the maximum capacity of pritning.. ^^
Jan 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Apr 03, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Won't print(after changing cartridges
blank pages and bad print are not the same problem. Regarding costly ink, a epson printer tech told me once that the secrete to cleaning a bad print head was to run deep clean 7 times in a row and then a head test and it has worked for me several times on other printers (not an expert here, just personal experience).
Additional note, I have seen both cleaning chemicals and cleaning cartridges on the web, example, searching google for one for my printer I would search for cc-bci-6c which is for a canon cyan cleaning cartridge. Don't know if they work but in case it helps.. good luck.
Barry,
Mar 02, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Lexmark X7350 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
