Question about Motorola Mobility i1 Smartphone
Can the Motorola i1 Nextel phone be reprogrammed to a Canadian Iden carrier (not Telus) and if so How???
  • i-den Apr 12, 2011
    That solution was what everyone says and would be a last resort if I was purchasing only 1 phone. I am looking for the ability to unlock 25 to 50 phones. Nextel, if you can find the correct person is not going to supply unlock codes 1 at a time.
    There has to be software out there to unlock all these units.
  • i-den Apr 15, 2011
    I already have that type of software. We are looking for software to unlock phones - like RaptorPro.
  • 2,069 Answers
Well for software, you could visit here.or download software directly here. free registration may be required before you can access download link. we don't unlock here that's why i have referred you to that free forum.
regards
Posted on Apr 12, 2011
  • 2,382 Answers
Hi, yes you can use your Nextel Motorola phone on any Canadian carrier. All you need is the unlock code of the Nextel Motorola that will enable any other sim carrier work on the phone. Contact Nextel and request for the unlock code by telling them you are travelling abroad and you intend to take your phone abroad with you and use another sim on it pending the time you return back to the country and the code with instructions on how to unlock it will be given to you if you persist because they normal refuse to give it out..
They may ask proof of ownership before giving you the code...
Posted on Apr 06, 2011
I own an i730 Motorola. Bought it a few years ago when I was with Southern Linc. I have never used it for anything other than the walkie-talkie. My Nextel i710 Motorola transmit button stopped working...
Hi, Welcome to FixYa
This document is also available in PDF format (this PDF has higher qualify images and a password and is not free. It requires purchase, with your purchase, you will receive the HEX file for Raptor Pro that's mentioned in this web page) for easier viewing and printing.
RSS Carrier + iDENPro
Phone Power: On
i-DEN phones are made by Motorola. They use SIM cards and look like GSM phones, but they are not GSM. The most popular iDEN network in the US is Nextel (now with Sprint) and Boost (owned by Nextel)
For most i-Den phones, use the RSS Carrier to put the phone RSS-SIM mode. Then use iDEN Pro.
It is recommended that you use the USB cable for Motorola iDEN phone when using RSS carrier and iDEN pro. Pay attention, the iDEN cable is very similar to the Motorola V600 cable, but a bit wider. So be careful not to confuse them.
RSS Carrier is useful for reading either the six-digit or four-digit phone or user security code. However, the actual unlocking of the Service Provider lock is done with iDEN Pro software.
Once you connected the phone, some times it will prompt you to install the driver, just follow the instruction and install it automatically. If it does not work, try to manually install the driver from the directory, which the Motorola RSS is located.
Assuming the driver has been successfully installed already. You should open the RSS Carrier software, click on File and Read Phone. This should put the phone into RSS-SIM mode.
Now you can exit RSS. Open the iDEN Pro software, and wait for it to detect the phone. Then click on Script | Open Script. Open a file under the iDEN Pro directory called “command3.txt” and then go to Script | Run Script. The phone should restart after the script is finished. Now test with a different SIM card.
Raptor Pro For a long time, Raptor Pro was not updated and stopped supporting any phones newer than the i405. However, recently the Raptor Pro’s hex file has been updated to support almost all i-DEN phones on the market. To unlock, i-DEN i880, i885, Raptor Pro (keep in mind the Hex File can be found under C:\Program Files\Raptor Pro\Hex File) has to be updated to support this type of phone. Make sure a SIM card is insider the phone and the phone should be on and ask for a special subsidy code. Then you should connect the phone using serial cable on COM1 and run Raptor Pro. It will take few minutes and give you the unlock code. It should be the first one. After getting your unlock code, try to put it into your phone with a different SIM.
Tip Some times when a person insert a different SIM and has entered the incorrect unlock code more than few times, the phone will show “Enter Special Code, Please Wait” or “Contact Service Provider”. In this case, you need to wait up to one hour for the phone to allow you to enter the unlock code again.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helped you.
Jun 30, 2008 | Lands Phones
Need a special code to unlock a Motorola i856
unfortunately these are not compatible. nextel is an iden carrier, while att is a gsm carrier. it's like apples and oranges. If you need to transfer contacts then you can get that done at any best buy. they will usually do it for free or for a minimal cost.. good luck
May 04, 2010 | Motorola Cell Phones
How do I unlock my nextel to work with other
you dont have to do anything at all. Just put your sim card in and go. I580 or any other motorola IDEN phone will only work on IDEN networks like (boost,nextel,mike,telus) It will never work for any other carriers no matter what you do.
Mar 08, 2010 | Motorola Mobility i580 Cellular Phone
Need special code to unlock motorola i560 phone for cingular sim card
Motorola IDEN phones will not work with any other carrier other then boost,nextel,mike,telus (IDEN networks) sprint,att,verizon,tmobile and most other cell providers run on GSM or CDMA. They run on a completely different band
Feb 25, 2010 | Motorola Mobility i580 Cellular Phone
I have a t-mobile simcard and is asking me for a lock code
If you are attempting to use a T-Mobile SIM card in a Nextel Motorola i730 mobile phone it will NOT work.
T-Mobile phones operate off of a GSM network. The Nextel i730 operates on an iDEN network.
The phone you have can never be compatible with the network you are trying to use it on.
Sep 07, 2009 | Motorola Mobility Naztech Nextel Iden...
I580 unlock code
this will not work, even if unlocked, they use two different networks, IDEN and GSM
Jul 28, 2008 | Motorola Mobility i580 Cellular Phone
GSM mode
First of all, what service do you use? I'd assume you are using Nextel, which is iden. For this reason, setting it to gsm doesn't work. iden was apparently the last setting used, so "last active" also works. Motorola, for some unknown reason, decided not to allow Nextel users to text message.
There are two ways around this.
1. One is to send a multimedia message with only text (no pictures, sounds, etc). This should be treated as a text message.
2. The other way is to follow this guide, which should allow you to change the registry on your phone and get rid of the message. Note that the first posters made the guide for telus users, so be sure to use the nextel sms number (found later in the thread, I believe).
Jan 01, 2008 | Motorola Mobility i930 Cellular Phone
Motorola Mobility i1 Smartphone Logo
136 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
