Internet not connecting after installing wireless router
    Sergeant:
    Champion:
  • 293 Answers
Did you reconfigure your new wireless router?
Posted on Aug 06, 2008
How do I do that
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
How to connect inenter by using lan and ftp
To connect to the Internet you need a few extra things aswell as a network card and install the LAN card driver.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
Jun 11, 2011 | Computers & Internet
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
Wireless configuration
What you will need: Wireless router and a wireless adapter connected to your PC. This is assuming you have a broadband internet connection. Install the wireless router by taking the ethernet cable out of the back of your computer and placing it in the WAN or internet port in the back of your router. Install the wireless adapter inside your PC. Unplug your modem for a minute or so. Then plug in your modem and your router, then turn on your PC. If you are running XP, it should see a list of wireless access points you can access. Select the one for your router (should be the strongest) and hit connect. This will connect you to the wireless router and the internet. Note this solution assumes the following: You have a high speed internet connection, your ISP's modem is connected to your computer via an ethernet cable, and you are running windows XP.
May 19, 2007 | RCA DCW615R Wireless/Cable Modem
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
