Question about HP Photosmart C6180 All-In-One InkJet Printer
I would like to scan a photo 10x 15 cm, but it is too small (normally it scans A4)
    Scholar:
  • 83 Answers
What does the engine light look like in a4 Audi 2004 1.8 quatro
i believe it looks like a small engine. if its flashing DO NOT DRIVE THE VEHICLE. get it to the dealer for a diagnostic scan.
Jun 06, 2015 | 2004 Audi A4 1.8
How can i chnage the dimension of the scan area? Up today the scanner was scanning A4 format but today its reduced to 1462X1568
Hi!
Before you press scan please check the setting on Solution menu. 1. Select Scan/import photo 2. Check at the right side and change 1462X1568 to A-4. 3. Press scan....... thanks
Sep 07, 2011 | HP Officejet 6500 Wireless All-in-One...
Is it possible to scan a tiny image, enlarge it to print out on A4 paper
yes you can scan a tiny image and print it out larger, but you will lose quality if you are going from very small to very big.
If you want to try it i recommend a program called Paint.NET (it is like a photo shop except totally free) here is a link to get it.    http://www.getpaint.net/download.html
You can scan the image and open it in Paint.net then go to this website which gives you excellent step by step instructions on how to re size an image: http://www.wikihow.com/Resize-an-Image-With-Paint.Net
after you are complete with that you can print it out and you will have an A4 paper size (Equivalent size in inches is 11.69" long and 8.27" wide.)
Hope this helps :)
May 03, 2011 | Office Equipment & Supplies
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
HP photosmart C4480 - 'scan to print' prints very small on A4?
You need to find the scan option on the printer and modify it.
Sep 02, 2009 | HP Photosmart C4480 All-In-One InkJet...
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Couple of problems for canoscan 3000f :
It appears the scanner is not scanning in the vertical direction.(I am assuming it is able to scan the full width). Try unistall and reinstall of the friver. This can work. There are sensors in the scanner that indicate the 'end of scan area'. Check if any of them is blocked by shreds of paper or dust.
S. Mohan
Feb 24, 2009 | Canon CanoScan 3000F Flatbed Scanner
Using PaperPort 11 to scan
If you will go through the Advanced Setup wizzard and it completes you will have access to the "Display Scanner dialog"
Jul 18, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Scanner Imaging problem
Your scanner’s lock switch may be locking up the carriage unit. Depending on the model you own, your scanner’s lock switch resides in one of two locations. You can find it beneath the scanner itself or in a corner next to the scanner bed after you lift the lid. The switch should be marked with a locked and unlocked padlock symbol; slide the switch to the unlocked padlock to unlock the carriage unit.
It’s also possible that the supplied USB cable is improperly connected to your computer. Connect the cable directly to your PC. Canon’s online documentation indicates that scanners that connect via a USB hub may not work properly. Once you have unlocked your scanner and properly connected it directly to your computer, try to rescan the image.
Mar 01, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
HP Photosmart C6180 All-In-One InkJet Printer Logo
248 people viewed this question
Seeker5211
Seeker5211
