Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960P Hi, My machine is just over a year old and the inside rubbers are going black and the smell is sometimes unbearable, there is also residue inside the machine door like a white slime. I use Persil and Ariel non bio. I do a 95 deg cycle but the smell is still there. It states in the book to leave the door open to eleminate smells but with a three year old son I cant. I had my last hotpoint machine for over 10 years and the rubbers didnt go black on it. I have made sure the pipes are straight and not blocked in any way I use my machine approx every other day. Anyone can help I would appreciate it. Regards, Andrea.
  • dvpeace Aug 15, 2008
    Hi
    My machine has the same problem - just over two years old - have tried to use products to eliminate mould - but to know avail. I am concerned that mould is growing in the machine - i think the only solution is to replace the rubber - but not sure if that can be done without someone who knows what they are doing
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Her we go again!
Every week run your washer once with no clothes inside, and on hot water with a 1/4 cup of bleach! This will kill the mold and get rid of the smell.Just remember to make your next load WHITE CLOTHES , so if there is a drop of bleach still in it some where, that it does not put a white spot on your favorite clothing.
Hospitals use a mixture of 1/3 bleach to 2/3 water to disinfect! kills all even in your shower or bathe tube and leaves the groat white!!!
If you ever need service in the future!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Error code F08 FLASHING WILL NOT SPIN
The pressure switch is stuck and the machine thinks it is full of water. You need to remove the top, look for the pressure switch and unplug the hose on it and blow air through the hose. Then replace the hose on the switch. It looks like this: http://www.yourspares.co.uk/parts/hotpoint/washing-machines/wt960p/parts/ys56011/hotpoint-wt960p-pressure-switch-spares-C00194160.aspx
Feb 06, 2016 | Hotpoint Ultima WT960P Washer Front...
Hotpoint WT 960G Smell from the machine when in use.
Usually the smell is caused by bacteria from the soiled water when washing is done on a cool wash. I have told customers before that to clear the smell you need to do several hot washes maybe using your white so as not to fade or run colours and in time the bacteria will clear and smell will also.
Feb 03, 2016 | Hotpoint Ultima WT960P Washer Front...
WT960P. How can I replace door gasket/seal?
It is held on with a plastic ring which has teeth to clamp it together to make a tight seal, these teeth have to be gently lifted away from their connecting teeth in order to remove the ring then the rubber seal can be gently pulled away from the machine and replaced with a new one.
Jan 29, 2016 | Hotpoint Washing Machines
Hotpoint WT960
get some descaler part No C00090908 that should sort the smell as for the seal you will better off replacing it
Jan 26, 2012 | Hotpoint Ultima WF860 Front Load Washer
Burning smell
Hi just read your posting.Now in my experience on your model of machine when you get a burning smell it is usually the pump.When the machine is draining the water and goes to spin do you get a burning smell then?Please try to look underneath the machine to the front right.You will should see the pump with a red or black fan attached to it.See if has any evidence of corrosion or leaking.Please reply with additional information and I can guide you throe rectifying this fault.
Jun 16, 2010 | Fisher and Paykel IWL12 Top Load Washer
Repair manual for hotpoint wt960p
The error code does not mean that the pressure switch is faulty, it is indicating a fault that affects the function of the switch.
The problem is actually a blockage in the pump or pump filter.
To rectify the problem, do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction hers as well.
This should solve the problem
Please leave feedback for my solution.
Thankyou.
Jan 19, 2010 | Hotpoint Washing Machines
Trinity Bendix 1000- inside smells of drains
are you using gel casules that go into the machine instead of powder if so stop using them and go to powder also put a small cap full of bleach in machine and put machine on a hot wash no clothes in.let machine rinse through
Jun 23, 2009 | Tricity Bendix WDR1040W Front Load Washer...
SMELLY WASHING MACHINE
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
Oct 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
219 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
