Question about Sony Computers & Internet
Screen is not lighting while laptop is running.
    Sergeant:
    Champion:
  • 217 Answers
There are 2 possibilties. Either the LCD power inverter is bad, or the LCD backlight. The inverter is not too hard to change and they are inexpensive. The backlight is inside the screen itself and you would need to replace the whole screen. Put the laptop in a dark room or area and turn it on. If you can see a very faint image on the screen it is probably the inverter. If so post back here to get replacement part locations and replacement instructions.
Posted on Apr 06, 2011
  • Sony Master
  • 6,771 Answers
Hook a spare monitor to the video output on the back of the laptop, if okay it means the video card is working fine. The problem is a bad inverter board, "located under the LCD display" or the back light is defective behind the screen, "usually means a screen replacement"
Laptop
If you shine a bright light at the faulty screen and you can see movement, the back light has failed otherwise the LCD/LED screen has failed. Purchase a new part through flea bay and follow the video prompts on utube showing you how to replace the screen.
Feb 03, 2014 | ASUS Computers & Internet
Tip
How to check if you laptop screen has gone out
turn on the laptop, if fan is running and the lights that normally work are working.
shine a bright light on the screen if you see a low lit display the screen is fine.
Its either your Backlight or screen inverter which provides the power to the screen.
on Feb 24, 2017 | Acer Computers & Internet
My toshiba satellite l455-s5008 screen display is black
it could be many problems first check if when you start up the laptop the hard drive runs it cuold be the screen of the laptop otherwise it has to be a problem with the mother board or the prossesor
Jan 24, 2012 | Toshiba Computers & Internet
Screen black and drive not running. No lights except ON which didn't turn off. Removed bat...went off. Replaced bat and only Power light came on.
Have you checked the Function Key combinations that switch your display to an external monitor, from the laptop's monitor?
May 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
My laptop lights turn on but screen won't show nothing
I have the same case with my laptop. I heard that if you run it with the battery out it could fix it! Try it I have not yet!
May 20, 2009 | HP Pavilion dv6000t Notebook
Screen doesn't light up
Brand new? please take it back to your dealer. I assume you do have it plugged to the charger and it has power? it doesn't matter if the battery is empty or not, the laptop works with the charger with or without and battery.
seems like you got a faulty laptop.
Apr 11, 2009 | HP Pavilion dv9000z Notebook
PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Computers & Internet Logo
109 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
