Question about Curtis LCD2425A TV
Can't change from HDMI1 to TV mode - Curtis LCD2425A TV
    Guru:
  • 868 Answers
Hi bev,
I see that you can't change from HDMI to TV mode, on your TV remote look for the button that should say input or source it should give you a list of input / source on your TV just select TV or there should be a TV button on your remote control for the TV, this should make your TV got to mode.
I hope that this will help you regarding your query, have a nice day.
Posted on Apr 11, 2011
Can't keep the HDMI2 setting for watching streaming channels - TV automatically reverts to HDMI1
That's because you have connected another device in HDMI1, the TV detects it as power on, and then change HDMI2 to HDMI1.
Try to power off the device in hdmi1, or you can even try to change HDMI2 to HDMI1 port ;)
Jan 15, 2018 | Televison & Video
My seiki tv got turned on to hdmi1 mode. How do I turn it off. I don't have an hd tv. The screen is blue and it says hdmi1 at the top and no signal.
you need to press source on the remote. That will let you choose what signal to use. TV, hdmi1, hdmi2, and more options will show
Oct 23, 2016 | Seiki Televison & Video
I have 32" hand spree TV hooked up to satellite box with a cable connected to the hdmi 1 port. Problem locking to hmdi1 port
Check in the menu of the tv do there is any option to select the input source. If so the select there its to hdmi 1. after that turn off the tv and ON again and check do it go back to TV mode.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 24, 2016 | Hannspree XV32 32 in. LCD Television
I was using this TV for my Wii Console. Now when switching on TV says: NO SIGNAL! I do not have a remote and do not know to search for signal. I changed cable to HDMI1 and 2 but no change
How did you operate and set up the TV without the remote previously?
In any event you can purchase a universal remote from an electronics store. Pick one that is marked as working with your brand of TV.
As long as the TV is set in the correct mode for TV reception and has the correct tuner, and as long as you can use that remote to access the onscreen menu, you will be able to set up a channel search and get TV reception restored.
Before you do anything just check that the TV is in the correct mode for TV reception and not set instead as a monitor for connection to another device.
Dec 27, 2015 | Video Game Consoles & Games
I am getting no service on my Samsung TV- using Direct TV. Also cannot reach service line which I pay for monthly.Samsung TV- Direct TV. Picturing working in Living Room, not in Bedroom.
Make sure the DirecTv receiver is powered, and the appropriate cables are connected correctly to the tv, then use your tv remote to change inputs to the one the cables are connected to. (Hdmi1 for hdmi1, etc). As long as you have the right input, and both items are powered, you should at least have a message on screen, if not programming.
Feb 27, 2015 | Samsung Televison & Video
55" Vizio LCD changes input when we turn volume up/down
hi it sounds like you have a software problem could be the epprom chip on the main board this is the memory chip, you could try the service mode and do a factory reset see if this cures the problem .
here is how you get into service mode Press "Menu," and then press "2," "4," "8," "9." do not adjust anything else just select reset , you will have to retune the tv in again hope it helps
regards
shaun
Apr 16, 2014 | Vizio VF550M 55 in. LCD HDTV
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
Deep sleep mode on digital tv
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Oct 28, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
When vewing tv sometime a box pops up saying not available in current mode
try changing the hdmi cable to hdmi1 slot, also try with component cables, since they are HD also. also check to see if tv is in air or cable status
Jun 09, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Curtis LCD2425A TV Logo
265 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
