Question about Lowrance MapCreate 6 and MapCreate TOPO CDs GPS Receiver
I cannot install mapcreate 6.3 on my windows 7 os. It won,t read the card reader. What can I do?
Compaq Presario Coprocessor conflict
Sometimes , when a Computer's OS is upgraded, form the original OS, you will find "Unknown Devices" in Device Manager. "Coprocessor" is common. Usually it's the Card Reader, try installing the driver for the Card Reader, Windows 7 32 or 64bit what ever OS Windows 8 is. You can find the drivers here, choose your OS 32 or 64bit, try Driver-Storage, Realtek USB 2.0 Card Reader, you must change compatibility of the Win 7 driver: Card Reader driver: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3927357 Change driver compatibility: http://www.eightforums.com/tutorials/6832-compatibility-mode-use-windows-8-a.html
May 17, 2013 | Computers & Internet
Tip
Drivers and Manuals for PIXMA ip100 Windows and MAC OS
Here I will show you where to find drivers and manuals for the CanonPixma IP100 printer.
Drivers for this printer are available for windows 2000, windows Xp, Windows Vista, windows vista 64bit editions,windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.2.8, Mac OS X 10.3.9, Mac OS X 10.3.x, Mac OS X 10.4.x, Mac OS X 10.5.x, Mac OS X 10.6.x
and some others.
A full on screen manual, quick start guide andother instructions are also available.
To download these drivers and or documentation foryour printer please visit
THISPAGE
1. Click on Operating system and select your operating system from the list.
2. Click on language and select your native language or english from the list.
3. click submit. A list of software and manuals will become available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA iP100v + lithium battery...
Windows 7 for downloading
Do you mean the Windows 95 OS or Windows 7? If you have Windows 95B (with USB support), get a USB card reader. You may need to add a USB card to your computer. (Look carefully at the manufacturer's site for the drivers, fewer companies are providing drivers for the older OS versions (before XP).) Windows 95a doesn't support USB at all. You would need a new OS. This is not guaranteed to work. If you upgrade Win95a to Win98, issues may still exist with the USB card reader. Remove the card from the camera and plug into the xD slot on the card reader. If the card reader works, you can use a version of Photoshop or any image viewer since your photos are JPEGs.
If you mean Windows 7, your computer might have an memory card reader. Check for an xD card slot. Otherwise, get a card reader (USB or internal that uses a 3.5" drive bay and connects to an available USB motherboard connector if you have one). Here is a source for several USB card readers: http://www.tigerdirect.com/applications/category/category_slc.asp?MfrId=0&CatId=2833 . Remove the card from the camera and insert it into the computer's xD slot. Then use the Windows Photo Viewer or any other image viewing or editing program to look at the pictures.
Open the card as you would any flash drive or optical disc. Go to Computer (My Computer) and access the card reader "drive", open folders to find the Olympus one. Drag and drop pictures to your hard drive or double-click to launch in the program linked to the JPEG file type.
Windows 8 will behave like Windows 7 with the card reader (for most readers).
I hope this helps.
May 15, 2013 | Olympus Stylus 410 / ? 410 Digital Camera
Toshiba Satelite SD Card reader driver
It's a common problem when you do a OS upgrade, Is that the only device in Device Manager that isn't working? Any Unknown Devices? You didn't supply the Model of Toshiba, or the original OS? Download and save the Card Reader driver for Win 7, Change the Compatibility of the driver and install.
Feb 03, 2013 | Toshiba Satellite Computers & Internet
Card Reader on tower won't work.
You must have checked the wrong model, because if its not there, then the PC didn't come with vista, and if you can't figure out how to find a driver, you didn't blow away windows 7, and clean install vista and find drivers for it. Check again. If someone else did load vista on it, then all you need to do is look at the driver for win 7, and see what the MFG is and then go to there website, if the driver does not have the name of the hardware, you can try using win 7 driver, if you get wrong OS, right click on the .EXE and choose properties and pick compatibility and set for vista.
Or just post the correct model like TAX asked.
Oct 30, 2012 | Lenovo Computers & Internet
My Kodak 50-IN-1 Card Reader won't read either of the discs in it
Most devices format chips in FAT, which is MS Windows format. Hope this helps.
Aug 26, 2012 | Kodak A250 50-In-1 Card Reader Universal...
Card reader does not work with windows xp
Hello you need at least service pack 3 from windows update
To make the reader working.
But there could be a conflict in the device manager.
Its not easy to tell what the problem is
but my guess is that its software related.
A computer repair guy can easy solve the problem for you
it does not cost much.
There is no drivers to be found for the device.
What happens when you disconnect the device
and connect it again ?
Try also to restart windows with the power on and see what happens.
Good luck
Aug 21, 2012 | Magtek 21040145 Magstripe Mini Swipe...
Hi , I have recently removed the windows vista and installed the Windows 7 Os in my Sony Vaio laptop.But now the laptop can not read the memory stick of my camera. could you please...
Hello. Most probably you need the driver for your card reader. If you give me the model number of your computer I can point you to the download link. Or also you can try fetching the driver from windows update within Windows 7.
Regards
Rob.
Mar 16, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Jun 02, 2009 | Lowrance iFinder H2O GPS Receiver
6 in 1 Card Reader
Which operating system you are using. ??
If its xp you have to download the drivers for card reader and see if it works, you can install the drivers with the help of windows update..
Oct 24, 2008 | Acer Aspire 8920-6048 Notebook
GPS Logo
271 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
