Question about HP PhotoSmart 7760 InkJet Printer
It says cartridge service station is stuck, and it is not. it won't let me print because it says this. how can I fix this???
    Genius:
  • 1,196 Answers
I will suggest you try reset the printer, follow the instruction below to reset your printer, if the problem still persist, replace the cable that connects the printer to the power outlet. If that did not still fix the problem, you will need to reinstall the driver of the printer, you can get it at HP web site.
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
Posted on Apr 06, 2011
Cartidges wont move
the cartridge as you call it is the carriage, which houses the inks and printheads, Its supposed to be 'Locked' at the service station until such time as the printer is ready to start printing,
what you should look for is a strip of what looks like clear plastic that runs the lengh of the print surface, give this a GENTLE clean with a cloth damped with WATER, ensure there is no paper blockage along the print path the cycle thhe power allowing the machine to come to ready or fault displayed
Mar 09, 2014 | HP OfficeJet Office Equipment & Supplies
I need solution on this Problem, HP DesignJet 500 Plus Error: Severe Error: 0x8010003, Thanks Biar R
Turn off the power ->open the cover and manually move the Cartridge carrier to the middle of slider bar that's all , it will fix your problem. Most of the time it is due to friction in the slider rod so lubricate the slider rod if necessary. If the carriage is stuck at the right hand side of the printer and cannot be moved out to the center of the print platen it is because the service station cannot uncap the print heads. in this case replace the service station/aerosol fan assembly.
Feb 13, 2013 | HP DESIGNJET 500 InkJet Plotter Printer
Empty carriage stuck in my HP 7500A printer
Hello,Lester Makang
Your carriage got stuck in service station,is there any noise coming from the right side of printer then there will be broken gear.
Power on your printer,after you got carriage jam error open cartridge access door and wait 5 second when you see that gears trying to move,use your hand to pull your carriage to left side.Don't use much force.If your carriage got free then install your print head and cartridges.If this will happen again then take it to service center they will change the service station or broken gear but the cost goes much high.
Nov 06, 2012 | HP Officejet 7500a E910 Multifunction...
DISPLAY BUSSY
Remove printer covers, put small peace of papers in door sensor & cartridge sensor,plug in power see where carriage stuck? Might be carriage stuck in service station,disconnect power, rotate manually service station gears for un locking the carriage assm.Once carriage unlocks check why it's stuck? Is there any paper partials jammed in side or service station movement obstructed by waste ink.. Remove service station clean with forced water, allow it to dry, apply silicon grease for smooth movement, fix it back.. test it..I hope this exercise will resolves you issue.. but its too dirty work,...
Jul 20, 2012 | HP Designjet 110plus nr InkJet Printer
Printer hp 8150 messages says cartridge server station stuck
Technical skills required to do this process, remove top,side doors, un lock carriage from service station, remove service station, clean & lubricate it for free movement, fix it back. try for print.. this is only solution for this issue, but mind that its dirty work...
Jan 04, 2012 | HP Photosmart 8150 InkJet Printer
Fast blinking red light, message says cartirdge service station is stuck
Solution
Follow these instructions to adjust the clutch on the printer.
Disconnect the USB cable.
Press the printer power button to turn off the printer.
Disconnect the power cord from the back of the printer.
Open the top cover of the printer.
Remove the print cartridges from the printer.
Slide the cradle to the right side of the printer.
Locate the clutch on the left side of the printer.
NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal.
Figure 1: Printer clutch
Remove the rear access door from the back of the printer.
Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
Release the clutch and roll the wheels up two more rotations.
Reinstall the rear access door.
Reinstall the print cartridges and secure the latches in place.
Close the top cover and reconnect the power cord.
Turn on the printer.
Print a test page.
NOTE: If the printer continues to display a Print cartridge cradle is stuck message or make grinding noises, click "contact hp" on this page for more support options.
May 26, 2009 | HP PhotoSmart 7660 InkJet Printer
Printer won't work
Let me guess, it moves freely otherwise but when it needs to print it fails? Sounds like the service station is broken. Sorry
Mar 21, 2009 | HP PhotoSmart 7760 InkJet Printer
Cartridge of My HP Deskjet 3550 Won't Move?
Friend,
Either the carriage is stuck in the service station or on the opposite side of the service station - at least it's jammed somewhere. The motor starts but cannot move the carriage.
I'd suggest you'd contact your local HP support, they should be able to help you fix this problem, or take the printer in for service if irt's still under warranty.
//Al
Jan 28, 2009 | HP DeskJet 3550 InkJet Printer
solution for...
" CARTRIDGE SEVICE STATION IS STUCK " with a blinking red light...
it's a bit difficult...just fixed it today....
first of all...u have to be sure that your service station is clear from any other old ink that maybe dried....that stuck the movement of the service station...
if it doesn't work again...folow the next step...
1. u have to pull out the service station... ( the difficult one ..!!! )
2. under the service station, there is a small motor....just find a new one and change it..
it works...
.....i found this new motor in an old hp printer's service station that i have...
thank u
Jul 04, 2008 | HP PhotoSmart 7760 InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
295 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
