I have kesintogton power adapter universal70 ac an i need tip for sony vaio serial number pcg5j2l whAT PART NUMBER I NNED THANK
    Sergeant:
    Champion:
  • 217 Answers
Replacement adapters are at this link. Click here. An important thing to remember about power adapters is you should not under power your laptop. This will cause battery charging problems and will eventually cause damage to the capacitors in the charging circuit. Look on the bottom of your laptop and you will see an information tag with power specifications for it. Voltage, amps, and watts will be listed. Make sure to finds a compatible replacement.
Posted on Apr 06, 2011
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
I have lost my sony vaio laptop and I wanna know it's imei number. Is there a way I can obtain that number? My model is Sony Vaio Fit 15E...
Laptops Dont have IMEI numbers,
Imei numbers have cell phones,
Laptops have Serial Numbers And Part numbers,
It looks like what you want is serial number, you can find on the laptop's box, it look like this : SN:XXXXXXXX
Aug 24, 2013 | Sony VAIO Notebook
Battery/Ac adapter issues for Sony VAIO Model
So I gather the laptop does not run when the battery is in and the AC adapter is not connected? Laptop batteries tend to ware down over time and will need to be replaced as they end up not being able to hold any charge. Look online for a new replacement of the battery under the model number of your laptop
Aug 13, 2013 | Sony VAIO PCG-K33 Notebook
Recently, the battery of my vaio died, but I could still manage by getting the power from outside sourse. However, I couldn't even turn it on last night, even though the vaio was still getting the power...
eventhough the light indicator on the ac adapter is still working, it doesnt mean that the ac adapter is still working fine..
  • the problem could be the ac adaptor itself, the dc in port of the computer or maybe the motherboard.
if the computer is still in the warranty, sony will cover the battery, ac adapter replacement, or process repair if needed. you can call them at 888 476 6972 or 239 768 7669
Mar 15, 2010 | Sony Computers & Internet
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Regards,
Purito
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Serial # recovery
service tag can only be found with yr systems present since yr not with the system i dont know.
thank u
May 26, 2008 | Sony VAIO VGN-AR230G Notebook
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Computers & Internet Logo
David Payne
David Payne
