Question about Siemens AX72 Cell Phone
Charging problem, charger & Connector OK, but Can't charging
  • 32 Answers
It sounds like the battery is worn down. Buy a new battery for it and it should work fine.
Posted on Apr 06, 2011
Charger ipod model a1199
http://www.everymac.com/systems/apple/ipod/specs/ipod-2nd-generation-nano-specs.html
USB Support:
Sync & Charge
Firewire Support:
Charge Only
Details:
The second generation iPod nano models are capable of charging and syncing by USB via the dock connector. It also can charge, but not sync via Firewire "400".
Connectivity:
USB
Ports:
Dock, Headphone*
Details:
Apple reports that this model provides "USB through dock connector."
*Ports include the "dock connector [and] stereo minijack".
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=9C41186E7131E6658B9324CCA
Aug 05, 2013 | Computers & Internet
How do i fix my tablet?
First off I was ask do you know if the charger is good? If it uses a USB connector to charge and you have another device with a charger, try swapping it out. Look on the tablet charger for the Volts (V) and the Amps (A) it will probably be 5V and 1-2A if you have a charger with a fairly close rating it should charge the tablet. You may also need to hold the reset button down for up to 20 seconds.
Jun 18, 2013 | Tablets & eReaders
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
My phone is not charging. when the charger is connected it shows the battery icon blinking as while on charging. but it is not charging & the battery was also OK .
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 11, 2010 | Motorola Mobility ROKR E6 Smartphone
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Nokia 7610 charging
First insure that is your charger ok? you can try it by using other charger. if your charger is ok then check your charging connector.but if the section is ok in your mobile charger section which name "k" is bad. then you need to change that. thanks
Feb 25, 2010 | Nokia 7610
The handset is on the charger but not charging
is your batterry is new?if that so,the problem is in the charger itself.but you can troubleshoot it by checking the wires of the charger if it is working enough..and also clean & rub the charger connector & the handset connector with a cotton buds to be wet with just a small amount of rubbing alcohol..
Oct 30, 2009 | Uniden TRU8885 Digital Answering Machine
My TV-1100 china phone does not charge. The funny thing is the phones of my friends with the same model which were purchased on the same date do not also charge and all these only happened today. The...
kindly check up with the stores in which the mobile was bought !!!!! & ensure that the charger ports in the mobile are functioning properly
Jul 20, 2009 | Cell Phones
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
My phone wont charge
check your charger first, if charger is ok then check the charging connector on the phone, clean it with a toothbrush and solvent cleaners.
Mar 27, 2008 | Samsung SGH-V200 Cellular Phone
Siemens AX72 Cell Phone Logo
276 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
