The brightness and sound indicator appear automatically(without pressing any buttons on the screen) on the screen and there is nothing that takes it away.
  • 27,725 Answers
Have you tried pressing the escape button on your keyboard
there are a number of things you could do to correct your problem
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
another thing you could try scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications if you see anything running that you dont want or need select end now
and another
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Posted on Apr 06, 2011
How do I rest the Service indicator for a 2005 CLK Cabriolet? None of the suggestions listed below worked for me.
First make sure all of the doors, hood, trunk, etc are closed.
Turn the key to position 1
Press system select button(lower left buttons on the steering wheel) that looks like sheets of paper until you see mileage reading or temperature displayed.
Press the brightness button on the lower left instrument cluster 3 times. You should hear a signal and see voltage on the display.
Turn the key to position 2
Press the lower scroll forward/back button(steering left arrows)). You should see "service indicator" on the screen
Press the Brightness button again once. You should see oil type on the screen.
Select the oil grade you used by pressing the + & - buttons on the upper right on the steering wheel.
Press the scroll forward/backward button to confirm. Confirm oil reset, press R(brightness button on lower left on cluster) for 3 seconds should appear on the display.
Service confirmed should appear on the display.
Press the upper forward/backward button & "service indicator" appears on the display.
Press the upper system select button(lower left steering wheel button on left) The display should go back to basic mileage or temperature.
If all else fails. I believe the shortcut I took as a tech was, turn the key to the first position, scroll until you see the temperature or mileage displayed. Turn the key off, push in the brightness button and HOLD it while turning the key to the 2nd position. You should see something like do you want to reset service? press R(brightness) button for 3 seconds and it should reset.
Good luck. The newer cars are worse.
Oct 10, 2013 | Mercedes-Benz CLK Cars & Trucks
How to brighten my screen on my computer
Locate and press the "-" button on the front of your monitor. This opens the Brightness/Contrast menu.
Press "+" button to scroll through the menu and press "-" to choose the Brightness control.
Press the "+" button to increase brightness and "-" to decrease brightness. The settings will automatically save.
Hope this helps
May 29, 2012 | Dell Computers & Internet
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
Apr 04, 2011 | Computers & Internet
Shut down my Acer 2480 wrong by pressing the power button. Now it doesn't reboot or boot up. I tried to pressing F2 to reboot but it doesn't do anything. Any suggestions?
Look at the power indicator:
If it is not lit, no power is being supplied to the computer. If the computer has a battery, it may be low and unable to power the computer. Connect the AC adapter to recharge the battey pack and make sure the AC adapter is properly plugged into the computer and to the AC power outlet.
If the power indicator is lit, check if a non-bootable (non-system) disk or USB thumbdrive is in the computer. If so, remove it and press Ctrl + Alt + Del to restart the system.
Pressing F2 by itself is only used to enter the system's BIOS on startup. If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
Apr 03, 2011 | Computers & Internet
On my yamaha v50 keyboard there is another sound on the keys after the c3 key how do i turn it off to just leave the synth sound?
you must do master reset!
1) Turn on the power.
TIP: All buttons must remain depressed and be pressed in the order mentioned in step #2 for proper execution.
2) Press and hold down the [SEQ] button, then the [CARD] button (located next to the Demo button), and then the [DEMO] button.
3) Continue to hold the buttons down until the dialog box appears in the display. The display will first indicate the V50 Test Program and Main Rom Version then will automatically display the question: 'Test Entry Manual?'
4) Press the [DEMO] button. The screen will display: 'Factory Set?'
5) Press the [+1/YES] button. 'OK' will appear beneath the 'Factory Set?' readout, indicating completion of the Factory Reset, and the V50 will automatically return to Play Mode.
Jan 10, 2011 | Yamaha Music
Hello. I want to ask. I have a Acer Aspire 9300 and I have a problem with it. When I try to turn it on it only ignites the green light and the computer does nothing and does not make any sound. What could...
First, make sure it is fully charged and plugged in.
If it is not lit, no power is being supplied to the computer. Check the
following:
If you are using on the battery, it may be low and unable to power
the computer. Connect the AC adapter to recharge the battery pack.
Make sure that the AC adapter is properly plugged into the computer
and to the power outlet.
If it is lit, check the following:
Is a non-bootable (non-system) disk in the external USB floppy drive?
Remove or replace it with a system disk and press <Ctrl> + <Alt> +
<Del> to restart the system.
Nothing appears on the screen.
save power. Press any key to turn the display back on.
If pressing a key does not turn the display back on, three things might be
the cause:
The brightness level might be too low. Press <Fn> + <→> (increase) to
adjust the brightness level.
The display device might be set to an external monitor. Press the display
toggle hotkey <Fn> + <F5> to toggle the display back to the computer.
If the Sleep indicator is lit, the computer is in Sleep mode. Press and release
the power button to resume.
Aug 28, 2010 | Acer Aspire 9300 Notebook
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Picture too dark
mkbowen,
whats the brand name of your TV?
also try this, facing the front of your screen. locate a button indicating " menu" and click it.
once the menu button been activated there would be a display box indicating "AUDIO" "VIDEO" "TUNNING" or in some cases the screen will indicate one by one setting every time you press the "menu" button. If you'll able to find a display indicating "video" higlight the said icon and navigate throught it until you see the control for brightness. you can navigate the icon by pressing +/- channel button and to change the value of selected item you need to press +/- volume button of the screen.
cheers ,
mark
Jan 18, 2009 | Quasar SP-3233 TV
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
