hi.defrost unit completely first 24/48 hours. or until there is water on drip tray above compressor.then turn it on .if it works it means your evaporator is freeing up.if it is the same it could be lack off refrigerant.good luck.ali
unfortunaly you will have to remove the back panals in the freezer to expose the evaporator... and spray with antibactirial cleaner.. as barcteria grows hear and causes smells... nothing to do with gassing.... if gas leaked out the appliance wont cool at all.... Rob
syringe out drain hole/pipe with clorine bleach(clorine will gas off and leave no smell after an hour or so)clean out tray with bleach,as it will kill the bacteria that causes the smell,the higher the himidity the more often you will need to clean drain/tray.(any clean water in tray ,use to feed your house plants,
Hi....Lift the softener cover off the tray and you will find the syphon tube or the cover underneath are blocked. Push some wire through the syphon tube to make sure it is clear and give everything a good wash.
