Question about Singer 2273 Mechanical Sewing Machine
I just got my first sewing machine- a Singer 2273 Esteem II. However, thread keeps bunching up under my projects. Everything I have read indicates my upper thread tension is too low, but I have tried different settings all the way up to 9. Is there any way to check/repair the upper thread tensioner?
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Mimito7
  • 128 Answers
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Posted on Apr 19, 2009
Zenqi
  • 208 Answers
SOURCE: Singer Featherweight tension assembly
Putting this back together is a thirty second job if you have done it a hundred times. If you have never done it but have mechanical aptitude, it may be a challenge.
Whatever you do, don't bend the check spring out of shape!
Below is a link to the Singer site with the schematic for reassembly. When placing the check spring back in place, place it in about the 6 o'clock position with no tension so that it has a fair amount of check before pulling it up in place..
When setting the tension, at a setting of "1" the tension disks should just be slightly compressing the beehive spring. "0" is almost no tension at all. Normal sewing is 5.
Get all of the parts together and push in the cup with the numbers while screwing on the knurled nut taking care to get the pin in one of the holes.
http://www.parts.singerco.com/CPpartCharts/2_2999/221-1_221K1_221K4_221K5.pdf
Posted on Jun 19, 2009
I have a Singer 2263 which is old but not used often. I am making aprons for Christmas, I made 3 and all the sudden the bobbin started bunching together. What can I do?
hi Sue.
Why does my bobbin thread keep bunching up? Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turned.
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little pop up will come up just close this down.
or try this one.
How to Fix that Tangled Nest of Bobbin Thread Under Your Sewing
or read up more at this link.
Why does my bobbin thread keep bunching up Google Search
Dec 13, 2017 | Singer Sewing Machines
On singer esteem ii 2273 model. My problem is the hand spinner sticks only when the needle is all the way down.It doesnt get stuck juststicky slightly. I cantfigure out where at its sticking. Any idea
In order to solve your problem, you may have to take the machine apart. The gears may have to be looked at and oiled. I would oil every joint.
Apr 25, 2017 | Singer Sewing Machines
Thread is bunching under fabric and I've rethreaded both the bobbin and the thread from the top multiple times.
Be sure your bobbin is inserted the correct way (this varies from machine to machine, so check the owner's manual). Bobbin tension is dependent upon this in most Singer machines.
Apr 03, 2015 | Singer Esteem II Sewing Machine - 2273
Singer Esteem II Model 2273 - Why is my Needle is always REVERSE mode !!
Ah... a plastic Singer. I'm sorry for you. It's likely something broke, take it in for repair.
Mar 19, 2013 | Singer Sewing Machines
I am looking for a free manual for a singer 2273 esteem II
Singer has the manuals for the 2273 on their support site: . The direct link to the English version of the manual for the 2273 is http://www.singerco.com/uploads/download/1181_2273.pdf . The oiling diagram is available separately: http://www.singerco.com/uploads/download/1235_oiling-2263.pdf . You will need Adobe Reader or a similar program to read the manual.
You can also buy the manual from Singer for $15. Many Singer sewing machine manuals are available here: http://www.singerco.com/accessories/instruction-manuals .
I hope this helps.
Jan 09, 2012 | Sewing Machines
I have a Singer Esteem II Sewing Machine model 2273. I ordered the ruffler foot 086742-P as listed on the website. I can get it to fit on the machine...i think...however when i lower the needle it hits...
Are there other needle positions on your machine that will allow the needle to pass without hitting? Otherwise, I suspect the accessory you have is not installed correctly or is not correct for your machine.
Jan 14, 2018 | Singer Sewing Machines
Where do I oil this machine?
You can only oil modern machines on the moving parts that you can see.
Jul 22, 2010 | Singer 2273 Mechanical Sewing Machine
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Singer 2273 Mechanical Sewing Machine Logo
241 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
