Question about Audio Technica ATWT702 Professional Microphone
When using the mic., It will want to change channels at the receiver from A to B. And when it does do this , it makes a poping noise through our main speakers. What could be causeing this and or the solution to solving this problem
    Champion:
  • 211 Answers
The switching from A to B means that the receiver is searching for the strongest signal.
They call it diversity reception.
The popping noise could be the level of the squelch, maybe you can in- or decrease it.
Just an option, worth giving it a try.
Regards Gerard
Posted on Apr 06, 2011
I have 2AKG UHFHT40ULTRA HIGH FREQUENCY handheld transmitter microphone , why when I turn them on they blink on and then notning ?
Okay, before going any further, let's just check....
  1. Along with your wireless mics, you have an AKG wireless receivers (e.g. WMS40 mini2), right?
  2. You've checked that mics and the receiver all work on the same frequency?
  3. You have connected both outputs from the WMS40 mini2 to individual mic channels on a mixing console?
Let's recap....
  • The AKG mics aren't going to work unless you have one of the matching receivers
  • The receiver has to be the correct type. This means if you want to run two mics at the same time, then you need a dual channel receiver (WMS40 mini2) otherwise they'll block each other. So, if you only have a single channel receiver (WMS40 mini) then you can only run one mic at a time, not two.
  • The mics and receiver have to be on the same frequency. They make it easy by colour coding the hand mics and the receiver. If the colours are different then they're working on different frequencies that are not compatible.
If you're good to go on all the above then the next stage is just the connection and set-up of the mics, receiver and mixer.
Since the mics are a pretty straightforward On/Off switch affair then there's not much to say there. Just make sure you maintain the correct distance for to ensure the wireless signal spreads out properly. It needs a minimum of 3m (about 10ft) distance between the mic and the receiver.
The receiver is straightforward too. It needs power, so make sure you plug in the mains adapter. The front LEDs give you the status of the signal. There's only two lights per channel, so it's easy to understand. RF OK confirms that the receiver is picking up the mic signal, so this one should be lit. AF CLIP let's you know when there's too much level from the singer/speaker. This could be that the receiver's volume control is set too high, or the singer/speaker is holding the mic too close for the volume they're producing.
The receiver's volume control needs to be adjusted fully counter clock-wise if connecting to a mixer by a balanced audio connection. If you're running in to the line level input, then the dial needs to be turned fully clock-wise.
The signal connection going to the desk should really be made with balanced leads. Jack to jack (TRS) or jack to 3 pin XLR will both maintain the noise suppression benefits of the balanced audio connection.
The rest is how you set up the mixer for the signal. Good luck.
Sep 14, 2014 | Audio Players & Recorders
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
Monitor Channel Making static sounds
Without hearing it it is difficult to be sure what is going on. What happens if you plug the main PA into the monitor channels, do you get the same? Are you trying to get too much into the monitors? static and popping are not the same to my ears, popping sounds more like you are hearing something that's there through the monitors that you're not hearing through the main mix as it may be masked. What frequency is the popping? Does it only happen when levels are high or when the singers are doing 'p' and 'b's etc? do you get it if you put the monitors on the main mix? Are you running the monitors into clipping (although I wouldn't expect this to create a popping? It sounds like a mix issue rather than a fault with hardware.
Aug 09, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
My mic output is very weak. Music comes out great. I have to set the levels all the way up to get any mic sound and usually there is a lot of clipping. You need to almost scream to get any sound with a...
Thiis amp has plenty of gain for mics. Make sure your mic has a good XLR to XLR cable (balanced) and connects to the XLR input connectors. If you have 1/4 inch jack cables that aren't TRS balanced on the mics, get rid of them and get XLR's.
Then push the PFL button down (LED will light red) for a single channel with a mic and adjust the trim (top knob for the channel) so that the level peaks without clipping on the main LED display when highest input to the mic is being generated. You should not get clipping then during operation.
After that you use the slider tio adjust the level for the mic. The MAIN slider should be at least up around -10 to zero during operation. If your main slider is way down, then you haven't balanced your channels properly. Do the same for each channel as the instructions for the mic above. If the gains of the other inputs are too high and the MAIN slider too low, this is what is causing your problem.
Typically the trims for mics like Shure 58 are about 3 o'clock.
High level guitars may have trims anywhere from 9 to 3 o'clock.
Ideally you will want your channel sliders to be between -10 and zero.
Sep 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Receiver is making a humming noise when turned up
your mic is misup that happein to my mic to so get i new one !!!!!!!!!!!!!!!!
Apr 14, 2009 | ElectroVoice Electro Voice RE-97TX...
No sound
tell ya when ya pay me prickfucks!!!!!!!!!!!!!!!!
Apr 11, 2009 | Televison & Video
All 4 mics wil transmitt through channel a,
Sounds like all of your mics are using the same frequency. What you can do is change crystals in each unit to change frequencies, this will allow each mic to use its own receiver.
Mar 31, 2009 | Pyle Music
We have a Sennheiser Diversity Receiver ew 100 and when the wireless mic is off the noise line is on the AF and makes alot of staic until you turn the mic on then it stops. How do I fix this?
Hello! Turn the unit on and push set on the receiver then push arrows until tune comes up, raise or lower frequency of the channel until the noise does not appear in the meter, push set to store settings then push power button to return to normal. Then take the mic and turn it on, push set then push arrow until tune comes up then push set and then set the channel the same way you set the receiver. P.S.. The receiver is locking on to a rouge frequency that is what causes the noise. Went you turn the mic on the receiver locks on to the mic and the noise stops.
Hope this helps you to fix the problem.
Steve
Jan 19, 2009 | Audio Players & Recorders
The main bus on my behringer 2222 mixer has gone. nothing patched to the main bus comes up on the main vu meter, and only a feint distorted noise comes out of the headhones when the main bus is turned up...
please make all your fader down-all your rotary control at middle(12 oclock position)------all your pressed pushbuttons in up position--disconnect all inputs cables----use good new cables for outputs---bring a good mic and connect it to any channel and raise its fader up and main mix faders up and check if the problem solved check your cables and your pressed button if not better to contact a good service center.
Aug 17, 2008 | Audio Players & Recorders
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
Audio Technica ATWT702 Professional Microphone Logo
64 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
