Question about MicroBoards MX-1 Disc Publisher Burner
CD seems to get stuck before it gets to the printer head. The duplicator will reverse and kick the CD back out. Not sure if it is the rubber wheel not getting good traction or something else. Sometimes the CD goes through with no problem.
  • cliff237 Apr 07, 2011
    I assume by CD tray, you are referring to the burner. It has nothing to do with the CD burner. It is when the CD is riding the conveyor belt to the printer. The traction wheel may very well be the problem. Is this difficult to replace?
    The problem ended up being ink overspray on the platen roller, making it slippery. Had to clean it and it fixed the problem.
    Guru:
  • 571 Answers
Seems that the printer is detecting bad cd's that's why it's kicking out the cd's. Make sure that the cd's are not bad.
Posted on Apr 08, 2011
    Guru:
  • 1,833 Answers
I assume the problem is in your CD's tray, somehow it malfunctioning and that's why it can not hold the cd into it and sometime it gets stuck. You need to repair or replace it. First try to replace the traction wheel, if the problem still exists, then you may repair it.
Posted on Apr 07, 2011
  • Aloke Das Apr 07, 2011
    It is not difficult to replace the traction wheel. You have to dismantle the drive gear mechanism.
Troy built storm 2890 snowblower slow in reverse
There is an inspection pan on bottom of snow blower remove the 2 or 4 bolts and drop pan
inside you will see an aluminum wheel (drive wheel) also a rubber faced wheel whitch runs on the aluminum wheel at a right angle (like a needle runs on a record on a record player.
Clean plate and rubber wheel using brake clean to degrease surface .
Also there is an adjustment to move the rubber wheel farther to the left for more reverse speed but in doing that you might lose top speed forward.
Mar 02, 2015 | Garden
2010 polaris sportsman 300 awd is not in awd in reverse is this normal or do I have a problem
Push the yellow button on the hand area. On some models, it engages 4 wheel drive
Jan 06, 2014 | Polaris ATV
How do i get the front wheel off i have removed wheel nuts whats next its solid
PUT ADDITIONAL BLOCKS UNDER THE TRUCK! OR A GOOD JACKSTAND! You no doubt have aluminum rims. They tend to oxidize to the rotors. Take a sledge hammer or some thing else functional and tap on the rubber of the wheel in a circular pattern. If it is really stuck, hit from the inside rubber to pop it loose. Also you can lower the jack to put pressure on the wheel and turn the steering wheel back and forth a little.Be careful please! Or in a pinch, just turn around and mule kick the tire!
Sep 16, 2012 | 2008 GMC Sierra 1500
I am trying to change the shocks for my 2003 Bravada and can't get the darn tires off. I need some advice. I have my lug nuts off and the vehicle is jacked up. Please help
So the wheels are stuck? Maybe get under the car and try and kick them off if they are just stuck on. Ive had alloy wheels do that...Maybe tap them with a rubber mallet and try and get them off.
Jun 11, 2011 | Oldsmobile Bravada Cars & Trucks
How to remove rear tires because seems like it is stuck
just kick it hard or use a big rubber hammer and smack the inside of the wheel
Mar 07, 2010 | 2000 Toyota Sienna
Dot matrix printer. very light print on last page of form
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
I have a 7 year old Lexmark 2381plus dot matrix printer. Recently, the print on the last page of the 3 part form has become very hard to read (very light). I changed the ribbon and have the form setting...
It would seem you posted twice.
Rear wheels not spinning. Front wheels spin when in 4 drive.
Hi First of all check the adjustment on the rear wheel thats sticking sometimes the brake pad comes away from the metal it is fixed to this maybe the case on your vehicle, the make & year of vehicle would help further but I a sure you got something to check now. Please leave me feedback, Malcolm Campbell.
Sep 23, 2017 | 1994 GMC Sierra
Ok I got the rubber band out
Hi Julia
Not sure where your problem is in the sequence of things. I am in France writing this so not at home to look at my Printer. From memory, once you have removed the wheel with the rubber band (tyre) on, rotate the band so a good part will be pushing on the paper and put the wheel back on the bar in reverseof how you took it off. The tabs on the wheel lock back in place holding the wheel to the bar. It's TIGHT in there though and I seem to remember it took a little bit of persuassion. However, f it seems impossble, then stop. You don't want to break it now you have got this far.
If this doens't help, drop me a line again in a couple of days as I will be back in the UK then and can have a closer look. I will try and post some pics too. Sorry I can't be more helpfull right now.
Regards
Palwing
Aug 14, 2008 | Samsung CLP 300 Laser Printer
Paper won't feed
The paper is pulled in with rubber traction wheels on a rotating rod where the bottom of the paper sits in the loading area. If these rubber wheels get slick or hard, they won't pull. Buffing the rubber wheels lightly with fine sandpaper will restore the wheels to the rubbery texture they need to pull the paper. But be SURE to completely clean any abrasive dust out of the machine before use.
Aug 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
MicroBoards MX-1 Disc Publisher Burner Logo
128 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
