Question about John Deere Garden
Manual trans. Goes into gear fine, but sometimes when I let out clutch It grinds and will not move. Rocking tractor fore and aft most of the time will allow trans to work. Always surges as if I had a big lump in one of the tires. I don't believe it needs entire transaxle, but some part or something needs repair. Thanks, Barry
  • 608 Answers
Needs the transaxle pulled apart and inspected. Possible loose sungear can.
Posted on Apr 11, 2011
Mid sixties Ford 4000. Suddenly decided to make severe grinding noise when trying to engage gears and cannot engage gears. Weirdly this does not always happen. Gears engage OK when engine not running
Hello, you may have more success in the proper category of lawn or farm stuff. Fortunately I have same Tractor. Sounds like clutch fork is not moving clutch the same way each time you press clutch. Could be clutch needs play removed. Sometimes there is a pivot ball for the clutch fork to rest on. When the pivot ball is worn the clutch fork can rock. Also remember RPM to give gears time to stop spinning before changing gears.
Jan 21, 2017 | Ford Cars & Trucks
When stopped gears sometime grind when shifting into 1st gear(2001 Ford Focus)
Then the clutch is not releasing properly & the continual
grinding will wear the gear teeth & you may also have worn
syncros, that will require you to pull the trans & go thru it, as well
as do a clutch replacement
Mar 09, 2014 | 2001 Ford Focus
756 goes in gear but tractor wont move clutch and trans is working fine
could be the transmission brake and torque amplifier dump valve on the multiple control valve on the left front side of the clutch housing needs to be adjusted
Feb 25, 2012 | Farmall IH Tractor 706, 756, 806, 856,...
93 C/K 1500 z71 1st gear and Reverse grind when cluth let out
the throw out bearing is bad ,so change bearing and clutch
Jan 22, 2018 | 1993 Chevrolet K1500
Getting a hard shift when going into overdrive. More obvious if I let up on gas and then back on when traveling hillier terrain. Less of a problem when getting on Interstate travel where speed is more...
Believe it or not, It might be the fan clutch. I fought my trans for 3 months with the same issue before I realized the fan clutch was bad. It would rapidly lock and unlock at the rpm range that the overdrive shifts at. Sometimes it felt like I was on a dirt road that was washboarded.
Check to see if the fan rotates freely 360 degrees(With engine STOPPED, of course). There should just be smooth resistance. Also check if there is any play by trying to rock the fan fore and aft. There should be no slop.
After I replaced the clutch, the trans shifted fine and even a check engine light went out.
A shuddering fan clutch will send hard vibrations through the truck and mimic a trans issue.
May 26, 2010 | 2000 Ford Ranger SuperCab
I have a 1998 accord 4cyl coupe manual trans. The
A clutch issue youtend to have more of an engagement problem with 1st and reverse gear for a small time period before you notice other gears.You want to check the clutch hydrolic system for any leaks(clutch slave at transmission,clutch master,which you look for leakage on interior above clutch pedal)and at fluid resevoir.you also want to double check condition of trans fluid. strongly recommend using only HONDA BRAND MANUAL TRANS. FLUID when doing maintinance,fluid should be replaced every 30k on this car.The Honda brand fluid is like night and day on these cars,it WILL make a difference in shifting!!TRust Me on this point! Sorry now back to your main clutch issue,when driveing and you go to shift gears and normally notice grinding,with clutch pedal in shft out of gear and before engageing it into next gear do a double pump of clutch pedal then see if when continuing to next gear if it engagees smoother.if so you know you have without a dout a clutch pressure plate/disc problem. I can tell you that in twenty years the only manual transmissions themselves that ever had problems were due to outside influences(gear oil in transmission,improper driveing,etc.)let me know what you find and we can go from there..JOEL
Oct 17, 2009 | 1998 Honda Accord
HELLO EXPERTS I have a 1995 jeep wrangler with 2.5 engine and five speed trans. I've put about 1000 miles on a new clutch, pressure-plat, throw-out bearing and slave cylinder. I am experencing the...
Check all your hydraulic connections for seepage . If you find nothing leaking, check where the rod goes into the master cylinder under the dashboard...If still nothing, I'd change the master cyl, as it is likely internally bypassing and permitting the clutch to release. PS it takesa a special "touch" to shift gears without using the clutch, if you cannot do that don't drive it Till you get it fixed...you will damage synchros and will need to have trans removed and rebuilt. $$$you don't want to spend!!!
Jul 12, 2009 | 1995 Jeep Wrangler
Clutch or tranny
Ok, Clutch engagement point should be midway or just before midway in relation to total travel.(pretty much the same in any clutch vehicle) assuming that if put in lets say 1st gear, with clutch in,then engine started, when clutch is released, car does not move but there are no unusual noises (grinding from inside trans.) If this is the case, I'd first check linkage for adjustment. If OK, remove the trans and look inside for broken gears, excessive metal debris etc.If shift rails are internal it could be that shift forks are sliding on rails and failing to engage synchros.
Jan 01, 2009 | 1998 Jeep Cherokee
Garden Logo
73 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
