Question about IBM Computers & Internet
I have a mother bd PN 49P1605. I am trying to identify the pin out functions for the front panel connector on the board.
    Problem Solver:
  • 7 Answers
1-2 Harddisk LED, 3-4 Power LED, 5-6 Reset Switch, 7-8 Power Switch
Posted on Apr 06, 2011
Testimonial: "Thank you . there was a previous answer left two years ago but it took a bit to find it. It matches this answer."
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
How to hook my power switch to my asus motherboard?
the front pannel on the mother board will be indicated some ware in the mortherboard the function is tha a3.3v must be shorted to ground for the computer to start if you have a multi tester then check the pin for voltage and short in with 0v the power switch will be different in motherboard the sequence of the front pannel is 10 Pin Panel connector (IDE LED, Power LED, Power Switch, Reset)
Jun 02, 2011 | ASUS P4VP-MX Motherboard
KK266 mother board (IWill) need a wiring diagram, usb is not being identified
Antec doesn't make mother boards, they make enclosures. The standard USB connection on the board is a 2x5 pin connector, with 1 pin missing. The end that has the missing pin, is the end that the cable shield is attached to.
Mar 24, 2010 | Antec Computers & Internet
Trying too install 4in1 card reader
If its an internal card reader, you should install it in the PCI slot. If it's an external card reader you should plug the card reader into the USB port. I need to know the brand and model of the reader so that I can give you more precise instructions.
Sai.
Mar 01, 2009 | IBM Computers & Internet
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
Wire came loose on pavilion xe 734 that supplie power to hard dir
First of all these wires don't supply power to HDD. These wires are for indicator LEDs on the front
panel of the cabinet. One wire `power sw' is to switch on the system from the power button on front panel. `power led' wire is of the power led on the front panel. All these wires will be connected to the cluster of pins on one corner of the mother board. If you can see it will be indicated & printed near the cluster of pins on the mbd, that which pair of pins is meant for what connector. Try to correlate the names on connector with the print on the mbd.
Jan 06, 2009 | HP Computers & Internet
MY Intel mother board D845WN can't boot
Try swapping those three connector plugs around from the front panel led lights to the other pins on the 9 pins connector, 5 in a row and 4 pins at the bottom. The bigger plug with 3 holes but only two wire will definitely go on the 5 pins row.
sirjohn
Dec 26, 2008 | Intel Desktop Board D845WN Motherboard
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
191 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
