Question about Custom Phones Animated Talking Mickey Mouse Telephone (TD/TS)
MICKEY MOUSE TALKING LAMP JUST STOPPED WORKING AND IT IS A 75TH ANNIVERSARY MODEL . ARE THERE ANY LOCAL REPAIR MEN YOU RECOMMEND? MY ZIP CODE IS 32162 IN FLORIDA.
Replace rear brake line hose on 2000 ford ranger xl 4x4
Not a hard job it will take a lil money tho u need the steel line long enough to reach from master cylinder to the wheel then just run the line along the old line I wouldnt remove the old line from clips unless you want to end up replacing them all. Securing the new line with zip ties will work
Jul 23, 2012 | 2000 Ford Ranger SuperCab
Dance star mickey
I just had this same problem. Micky danced and moved his mouth but no sound. I opened up Mickey's outfit at the back of the neck up to the top of his head and found a broken wire. I spliced the wire back together and Mickey works again! The 2 wires go from the back center of Mickey's head to the top of his left shoulder. Hope this helps someone else!
Jan 08, 2012 | Disney Fisher Price Dance Star Mickey...
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
How to contact the Rainbow local distrubutor in Dubai? Thanks!
hi ... did u fine the local distributor in dubai?? im looking for one too but cant find any!! please let me know if you foud one!!
shafaq.asad@hotmail.com
thanks
Nov 07, 2010 | Rainbow 75th Anniversary Canister Vacuum
I have a Woman's Mickey watch that has "Disney Time Works" on the back of it. I would like to get a new band for the watch since after 10+ yrs it is very worn. The band is gold tone but it has not the...
mcdevito75 here, Any small watch repair shop can replace the strap for you. Ebay may have Mickey Mouse replacement straps if you"d like a Mickey Mouse strap.
Sep 24, 2010 | Disney Watches
Can't delete pictures
To delete pictures....Use the right arrow button to highlight the the check mark that is on the left side of the screen & then press the red big red x button on the camera.
Dec 22, 2009 | Disney Mickey Mouse Camera - Mickey &...
I have a minnie mouse that was made in 1928! does any one no howmuch itz worth its called classic mickey!! please
mcdevito75 here, hello miss d, the first Mickey watch Disney came out with was in 1933, Mickey was invented in 1928, if this is a picture of your Mickey above, then it wa made in the early 1980"s. If it's working very well it could be worth a collector value of approx. $30.00 --$50.00
Dec 08, 2009 | Disney Since 1928 Classic Mickey Mouse...
Rainbow SE power nozzle
If the brush is spinning ok, and the belt isn't slipping, then probably the circuit breaker is bad, or the motor is causing the problem.
Oct 23, 2007 | Rainbow 75th Anniversary Canister Vacuum
Rainbow vaccum
Make sure the bowl has the pin on it. The Vacuum has switch in the bottom that keeps the Vacuum from running if the bowl in not on or the little pin is broken off.
Ralph Wakeman
Ifix@shentel.net
Oct 18, 2007 | Rainbow 75th Anniversary Canister Vacuum
Custom Phones Animated Talking Mickey Mouse Telephone (TD/TS) Logo
161 people viewed this question
Top Custom Phones Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Custom Phones Lands Phone Expert? Answer questions, earn points and help others
